New and improved Optifuel Flow Sensor
OptiFuel
Postby OptiFuel » Fri Nov 25, 2011 2:50 pm
Take a look at our new all aluminium body flow sensor design.
The harness and flow sensor can also be separated via the removable clip on the sensor body.
Please visit http://www.optifuel.co.za for more information
Martinvt
Re: New and improved Optifuel Flow Sensor
Postby Martinvt » Mon Nov 28, 2011 1:01 pm
Hi There,
It works great.
I have the flow sensor on my 503 Safari. and it works great. It is very accurate.
Thanks for the great Tech. (^^) (^^) (^^)
Martin van Tonder
Aerotrike Safari
ZU-CIE
Vertical Tango
Postby Vertical Tango » Wed May 16, 2012 4:07 pm
Please allow me to brag about the instrument. (!!)
I did the test of the tests last week-end. Flew from Krugersdorp to Battlefields Lodge in my Xenon. The logistics involved required fine calcs of fuel requirements, and I knew that I would cut it fine to reach destination one shot. The gyro is a thursty machine at 22l/hr average. As I took off, within minutes, the instrument told me that I would have 35 minutes reserve on landing. I got on few occasions serious headwinds that dropped the reserve to 20 minutes at times. The peace of mind comes when calcs are done every second ! That allowed me very early to keep Newcastle as an alternate. However, passing the escarpment at Volkskrust changed wind conditions and reserve went to 28 minutes which it stayed to landing. 10 litres was left in the tank as expected.
The return flight was very similar, with a strange thunderstorm in JHB at 14:00 to add to the stress. Landed with 9.5 litres.
I did the test to show that you can trust the instrument once it has been calibrated to your aircraft, but would never advocate to cut it that thin ! :oops:
