Does anyone know who I can speak to regarding the purchase of the flightcomm, or same type and size RCA jacks for my headsets? I want to make an extension and need a male and female type adaptor...
Any help would be greatful...
Blue skies
Hi Justin, did you try Communica or Philtron in PTA?justin.schoeman wrote:When I was looking, I eventually gave up and ordered from Aircraft Spruce... You can also try Placo - they occasionally have stock.
That was my first stop. The 5.2mm jacks are only used for aviation - there are no other commercial uses, so none of the usual suspects stock them.JvTonder wrote:Hi Justin, did you try Communica or Philtron in PTA?justin.schoeman wrote:When I was looking, I eventually gave up and ordered from Aircraft Spruce... You can also try Placo - they occasionally have stock.
