iPhone/iPad Logbook Development
- THI
I have tried a couple of different logbook apps but there are none that tick all the boxes. I'm so frustrated that I'm thinking if developing my own app. Very basic but very useful. Anyone interested?
Any apps that anyone can recommend?
Ps. Same goes for my vehicle logbook.
Re: iPhone/iPad Logbook Developement
Hi THI
I would be very interested in a app like that also went thru the hole list of iphone app's and like you could not find any thing that ticked all the boxes. A weather link on the app will also be nice
JUDGE
- THI
Hi Judge,
What would you like to see? We should maybe start in different versions?
I was thinking to make the layout +- the same as the typical pilot logbook:
Date - From - To - Hours etc.
Maybe a summary page?
All can then be exported and email.
Your thoughts?
Your thoughts?
- Technocrat
- First solo
I use the attached LSA Logbook format. A monthly summary of the following would be nice:
Hours per pilot (will only work if all pilots enter info on same iPad
Average fuel comsumption per hour
- Flight Folio LSA1.pdf
- (22.36 KiB) Downloaded 358 times
- Jabbanaught
Thinus which apps have you tried , thus far ?
Autogyro - Calidus ZU- ???
Magni M22 - ZU EGA
Magni M22 - ZU EGA
With all these ideas I would Think you would log on to a cloud based log book system from any ipad or iphone I have heard there are a couple of free cloud base servers that could be used.
What also could be very useful is a plot of the route on Google maps and maybe met data.
Well THI I’m not an apple expert but I could try
JUDGE
- THI
@Technocrat - This is purely for the pilot and not the aircraft. Maybe this would be the next step, do develope one for an aircraft?
@Jabbanaught - I have downloaded a bunch and deleted them as I went thru them. The last apps on my iPhone are MyFlightbook, Logbook Pro, PilotLog, FlightBOX, AvConnectLT. The problem with some of these appsmis that you need internet access to start logging a flight. Some of these apps don't even have FASX in their DB and you can't insert a unknown airport
@Judge - No need to be an Apple expert
Just to bounce a few ideas and give a developer something to work with.
I just need something simple. Date of flight, from where, to where and time flown. Easy a pie...?
What about the Androids?
Is a web based app not still a better option as opposed to be platform specific?
- THI
The problem I have with web based is that you need access to the net to "work", no? In some areas the cellphone signal is not strong enoughskybound® wrote:What about the Androids?![]()
IIRC, the programmers do the development and then compile to what platform, Apple or Android. So I don't' think it will be a problem??
Thinus Enslin
Potchefstroom (FAPS)
ZU-CML
Would love a RV10 though...
ZU-CML
- Air Hog
- The Boss
As far as I know Aviation Direct is launching an I-pad app towards the end of November. They also did the popular Easy-Plan which include a Pilots logbook that is CAA approved.
- THI
Hi All,
Just some feedback. I have spoken to a developer that might be interested. He as done two apps which I have used for some time now, KiloFuel & PowerTrack.
The thought is to start with the following:
Date
Pilot
Aircraft
Aircraft Type
From
To
Hobbs Begin
Hobbs Stop
Flight Duration
Fuel
Notes
What about GPS location service? Would that be necessary?
Any other inputs / comments?
Date
Pilot
Aircraft
Aircraft Type
From
To
Hobbs Begin
Hobbs Stop
Flight Duration
Fuel
Notes
Thinus Enslin
ZU-CML
ZU-CML
Should sync through iCloud so you can enter either via iPhone/iPad, as well as the obvious advantage of backing up to 'the cloud'
I have Air Nav Pro on my Iphone for backup, main is a 296
The Air Nav has a lot of the SA Airfields and use airfields can be added.
It has a logbook function and does monthy and yearly summaries
Date
Aircraft Reg
Dep Point & time
Arrival Point & Time
Total Time
No of Landings
Notes
Has many features drop me a mail and I can send you the user manual (8 meg)
Date
Aircraft Reg
Dep Point & time
Total Time
No of Landings
Notes
Claude
- THI
I have tested a lot of apps without success. I can't convince myself paying $40 for an app that might not work
Ok, maybe talk to the EasyPlan/cockpit guys, they are busy converting the EasyCockpit to an Apple app.
Claude
Users browsing this forum: Bing [Bot] and 11 guests
