Hi Biggles.
They fit the Airmagic peltor headsets perfect!!
I have used the helmets with David Clark, pilot comms, MGL, and of course my Brand GTFLYCOM headsets. I belive they will work with any headset make if the padding is removed that goes on top of your headset. And they sit vare comfortable....
Give me a shout if you are interested.
Gerrit or Michelle
0824000351
0121110085
Microlight Helmets
- Gerrit.Tromp84
- I hate bird strikes
Re: Microlight Helmets
GTFlycom
Info@gtflycom.co.za
0824000351
0121110085
Info@gtflycom.co.za
0824000351
0121110085
- Biggles
Already talking to Michelle to finalise order.Gerrit.Tromp84 wrote:Hi Biggles.
Gerrit or Michelle
0824000351
0121110085
Trike pilot
Aerotrike Scout
ZU-DNP
Aerotrike Scout
ZU-DNP
- Gerrit.Tromp84
Hello Guys.
Winter special on flight suits R1450.
Thermal -5 degrees touch screen friendly gloves R350.
Neoprene neck warmers R250
Helmets with Bibs R1700
Place your orders now to avoid disappointment.
Gerrit & Michelle
GTFLYCOM
www.gtflycom.co.za
0824000351
0121110085
Gerrit & Michelle
GTFLYCOM
www.gtflycom.co.za
0824000351
0121110085
GTFlycom
Info@gtflycom.co.za
0824000351
0121110085
Info@gtflycom.co.za
0824000351
0121110085
- Signed up at flight school
I recently purchased one of Gerrit's helmets and I would like to say (after several hours in my trike): perfect fit, comfortable adjustable chin-strap, very comfortable fit with my headset, great slightly tinted visor with adjustable tension. Slight negative is that the strap adjuster on the "female" side (LHS) can slide under the release clip making it difficult to unclip? Maybe I'm doing it wrong but I don't think so; will see what the solution is and revert. The triangle of the strap from the helmet to the clip is also quite small and does not go over the headset earpiece...this is not necessarily a negative, in fact I think in retrospect it's actually the opposite because the strap serves to additionally hold the headset against the ear / checker more snugly for better insulation against wind noise the previously crept through.
Thanks Gerrit and Michelle, great service!
- Gerrit.Tromp84
Hi Steve.
Thanks for the complements.
Regarding clip issue. One can cut the slider off and remove it from the straps. This helps both for increasing length and avoiding it to slide in under the clip.
Let me know if this resolves the issue.
BR
Gerrit
BR
Gerrit
GTFlycom
Info@gtflycom.co.za
0824000351
0121110085
Info@gtflycom.co.za
0824000351
0121110085
THANKS GERRIT, ISSUE SOLVED. WORKS GREAT, LOVE THE HELMET.
Users browsing this forum: No registered users and 155 guests
