Just some comments ( quoted from this site:
http://www.synergysupplycm.com/pdf/Hydr ... 20like.pdf )
There are several classic ind i c a t o r s o f a r e a l h y d r o g e n embrittlement failure. If any of these factors are missing, then the failure must be attributable to something other than hydrogen embrittlement. These five characteristics are:
1. The failure must be a DELAYED failure. The delay is generally from one to 24 hours after installation. If the failure occurs during installation, it is definitely NOT caused by hydrogen embrittlement.
If the delay is a week or later after installation, the cause is probably stress corrosion and not hydrogen
embrittlement. The failure modes and metallurgical appearances are identical in stress corrosion failures
and hydrogen embrittlement failures. The primary indication of stress corrosion is that the delay is longer
than 24 to 48 hours after installation. More details on stress corrosion will be dealt with in a later article.
2 . The fasteners must be hardened to at least Rockwell C37. Unhardened fasteners never suffer from
hydrogen embrittlement. Fasteners that have a hardness of Rockwell C36 or less are extremely unlikely to
ever suffer from hydrogen embrittlement.
The greater the fastener’s hardness above Rockwell C36, the greater the chance that the part will experience a failure attributable to hydrogen embrittlement.
Inch socket head cap screws, L-9 bolts, metric property class 12.9 screws and bolts, and spring steel
washers and roll pins are the common fasteners which
are most susceptible to hydrogen embrittlement failures because of their high hardness.
3. The failed parts must be electro-plated. The creation of the hydrogen in the metal fastener is caused
by the cleaning processes where acids are used and not by the actual application of the plating. I have heard
of many cases where non-electroplated parts were suspected of hydrogen em-brittlement, but I am not aware
of any that were confirmed to have failed from hydrogen embrittlement.
4. The appearance must be that of an “intergranular” failure. Look closely at the surface of the broken areas
in the photograph in this article. The surface of the failure looks relatively smooth with a texture that looks
like the surface of emery cloth. If you look at it under magnification, you see that the surface has a crystalline appearance with many sharp faces or facets. Some describe the appearance as being similar to broken rock candy.
A bolt or screw failure caused by excessive torque or tensile stresses produces a failure surface that has
peaks and valleys in it which is referred to as “dimpling.” This is also technically referred to as a “ductile”
failure as opposed to a “brittle” failure which is characteristic of a hydrogen embrittlement failure. If you look
at the failure surface of a bolt or screw failure surface
that has peaks and valleys and/or a swirling appearance. The failure is highly unlikely to be attributable to
5. The failure location is either where the fastener’s head connects to the body or in the threads within two
thread pitches above where the bolt’s thread engages the mating thread
also see that hydrogen embrittlement are often false blamed.
http://www.synergysupplycm.com/pdf/Hydr ... 20Info.pdf
It is still better to avoid using plated high strength bolts but if they have been in your plane for a while it is very unlikely that they will fail due to hydrogen embrittlement.
