Fuel Filter
Fuel Filter
One of my friends fly a aquilla with a silver top 582.He wants to change the filter.I use a mercedes benz diesel filter on my 503.Can he also put the someone on that I use?
- Wargames
Re: Fuel Filter
If he also uses pre-mix. He should use the same filter.
If he has a auto lube system, he can use the same filter, or anything with similar flow rate.
Re: Fuel Filter
Thanks.Wargames!He indeed premix!Wargames wrote:If he also uses pre-mix. He should use the same filter.
