Hi, has anyone got some advice on a fuel flow meter. Running a 503.
I would like to install one, but I don't know what is the best option for this and what will be a good accurate unit.
Advice please?
Fuel Flow Meter
- Cee Vee Ess
- Passed radio course
Re: Fuel Flow Meter
Optifuel
Dave Lehr
Magni Gyro M22 ZU-EPZ
Re: Fuel Flow Meter
MGL also very good
Re: Fuel Flow Meter
Hi There,
I recently bought a OptiFuel with the new flow sensor from Stephane at Optifuel and it works great. It is very accurate and easy to install.
I am using it on my Safari with a Rotax 503.
Martin
Martin
Martin van Tonder
Aerotrike Safari
ZU-CIE
Aerotrike Safari
ZU-CIE
- Cee Vee Ess
Re: Fuel Flow Meter
Thank you fellows,
Will look into those two options then.
- Alpha
Re: Fuel Flow Meter
I Second this...I also run a 503 and have installed an optifuel..brilliant and easy to install...also very accurate...Martinvt wrote:Hi There,
Martin
ZS-WGT
ZU-AAS
ZS-WGT
ZU-AAS
- V
- Whats the right frequency?
Re: Fuel Flow Meter
I installed an MGL Infinity fuel flow meter on my trike with 503. Easy as a pie. A tad more expensive than the Optifuel, but I had MGL instruments already and the MGL fuel flow meter takes airspeed information from the MGL ASI to calculate (air) distance to go. It accepts GPS input the same way as Optifuel, but I had no suitable GPS at the time ...
I think, both devices work great, they are wonderfully configurable and easy to calibrate.
Cheers,
V.
Cheers,
V.
- Biggles
Re: Fuel Flow Meter
I have MGL and appart from the fuel flow... the incorperated programable fuel level sender is a god send. especially on our wonky shaped tanks. Once calibrated the fuel shown is what is in the tank.
Trike pilot
ZU-DLP
Winelands FAWN
ZU-DLP
Winelands FAWN
