Safe QNH
Safe QNH
I want to know what a safe Qnh is to fly in?The other day it was 1028. My trike did not climb lekker out!I know 1018-1024 is safe.
Re: Safe QNH
Hi Henning - I am not so sure you have a complete understanding of QNH. Using your example, your aircraft would in theory, all else being equal, have performed better at the higher QNH, because the air is slightly denser, so more lift, on the wing and the propellor, more oxygen per stroke of the engine so more power. This of course is often so small that it is not noticeable. I strongly suspect that a trike with a half full tank at a QNH of 1010 will perform much the same as a trike with an additional couple of litres, at a QNH of 1020. ( I have no imperical data to prove this, it is only a gut feel, but it is that order of magnitude.)
The difference in air density between 1010 and 1011 mb is 30 feet, so really it is not that significant for us trike flyers
Re: Safe QNH
Today I flew at 1030. No problems. Admmitedly it was in a Savannah.
Vernon.
P.S. I know Dobbs is going to have something to say!!!
Vernon.
Re: Safe QNH
Vernon, I am not so sure that your aircraft flies, it is more a case of the earth repelling it
OK OK I take that back
Have you put you fat tyres on yet?
Re: Safe QNH
Thanks Dobbs!Dobbs wrote:Hi Henning - I am not so sure you have a complete understanding of QNH. Using your example, your aircraft would in theory, all else being equal, have performed better at the higher QNH, because the air is slightly denser, so more lift, on the wing and the propellor, more oxygen per stroke of the engine so more power. This of course is often so small that it is not noticeable. I strongly suspect that a trike with a half full tank at a QNH of 1010 will perform much the same as a trike with an additional couple of litres, at a QNH of 1020. ( I have no imperical data to prove this, it is only a gut feel, but it is that order of magnitude.)
Re: Safe QNH
Not yet Donovan. I ordered new tubes through Brett. I am a bit worried about the other tubes.Dobbs wrote:Vernon, I am not so sure that your aircraft flies, it is more a case of the earth repelling itOK OK I take that back
What did I tell you? ( you forgiven)
Regads
Vernon.
Re: Safe QNH
Following on from the above responses, you do, indeed, appear to have your understanding of QNH reversed. However, aircraft performance is based on Density Altitude.
Without getting into the details... DA is a factor of the Pressure Altitude (QNE) at a given elevation, adjusted for for non-ISA temperature.
For every 1 hectopascal decrease, "relative altitude" increases by a factor of 30ft. HOWEVER, for every 1 deg. C increase, "relative altitude" increases by a factor of 120ft.
Therefore, it is more prudent to have checked what the temperature was at the time of for flight, as it would have a greater bearing on performance.
Re: Safe QNH
Hi Android, thanks for reminding me that temperature in fact plays a greater role than QNH
- John Boucher
Re: Safe QNH
