E-Box - free play?
Gannet
E-Box - free play?
Postby Gannet » Fri Jul 29, 2011 7:46 pm
I have noticed about a 1 cm or slightly more free movement in my 72" P-Prop tip movement, before the crank of the 582 turns. What would be 'normal' free play?
Bushbaby Safari ZU-JXF
Re: E-Box - free play?
Postby Boet » Fri Jul 29, 2011 9:43 pm
Godfrey, that is about normal! vhpy
Postby Boet » Fri Jul 29, 2011 10:05 pm
Maybe I should explain a bit better. The tip of the prop is 36"" from the centre of the prop shaft. Check the free play at the edge of the propshaft, and you will see the correct end play there. But then to be on the safe side, I will look it up in da book, and report back!
Fly safe, and enjoy your Baby. When you flying up to come smell the blommetjies?
Gannet
Postby Gannet » Fri Jul 29, 2011 10:50 pm
Boet, just as soon as you report that they are bloomin' lovely! I look forward to your report back from the books!
Sukkelaar
Postby Sukkelaar » Sat Jul 30, 2011 2:26 pm
Hallo Boet
Gee daai koordinate dan kom se ek hello
groete
Kyk Noord
Postby Boet » Sat Jul 30, 2011 9:13 pm
Next weekend and the weekend thereafter ..... should be blooming nicely by then. Sukkelaar, moenie net belowe nie. 30 grade 54 Suid 19grade 25 Oos. Hoogte bo see:3000 voet. Langste runway is 1.2km lank. Lank genoeg?? :roll:
Postby Duck Rogers » Sat Jul 30, 2011 9:26 pm
Gannet wrote: What would be 'normal' free play?
That IS the 'normal' free play.
Stop stressing and go fly!
Gannet
Postby Gannet » Sat Jul 30, 2011 11:07 pm
I did today - just awesome conditions! Clocked 2 hours. Thanks for the assurances!
