Nomex Suits
Jabbanaught
Nomex Suits
Postby Jabbanaught » Mon Jul 11, 2011 12:49 pm
Hi Guys
The current nomex suits available on the market is very much like an old ARMY Overall , with one zip in the front , this makes it difficult to get in and out of . Furthermore if you get hot you can only unzip the front, this suit offers several zips to cool you down .
Ronnie Chapmann bought Nomax from a racing supplier here in Cape Town , Its single layer Nomax , He then had a suit made like he had in his old trike days , but for a bit of insulation , A polar fleece was added to the nomex on the inside .
This now offers you a nomax suit that you can get into easier (see photo's) and is warmer than just a single layer nomex .
Easy to step in
Suit 1.JPG (47.63 KiB) Viewed 2698 times
Autogyro - Calidus ZU- ???
Magni M22 - ZU EGA
Jabbanaught
Re: Nomax Suits
Postby Jabbanaught » Mon Jul 11, 2011 12:51 pm
Velcro at the bottom to close up , stops cold wind coming in
Suit 2.JPG (51.36 KiB) Viewed 2697 times
Magni M22 - ZU EGA
Jabbanaught
Re: Nomax Suits
Postby Jabbanaught » Mon Jul 11, 2011 12:52 pm
Closed
Suit 3.JPG (49.44 KiB) Viewed 2697 times
Magni M22 - ZU EGA
Jabbanaught
Re: Nomax Suits
Postby Jabbanaught » Mon Jul 11, 2011 12:54 pm
Long zip infront to make it easy to get into.
Magni M22 - ZU EGA
Jabbanaught
Re: Nomax Suits
Postby Jabbanaught » Mon Jul 11, 2011 12:55 pm
Zip on the sides to help with cooling in summer !!
Suit 5.JPG (49.22 KiB) Viewed 2695 times
Magni M22 - ZU EGA
Jabbanaught
Re: Nomax Suits
Postby Jabbanaught » Mon Jul 11, 2011 12:57 pm
Collar zips up high to prevent cold coming in !
And plasce for your badges (^^) (^^) (^^)
Magni M22 - ZU EGA
Jabbanaught
Re: Nomax Suits
Postby Jabbanaught » Mon Jul 11, 2011 12:58 pm
Fleece material visible for the cold days !
Magni M22 - ZU EGA
Jabbanaught
Re: Nomax Suits
Postby Jabbanaught » Mon Jul 11, 2011 1:00 pm
BADGES
Magni M22 - ZU EGA
flying-i
Re: Nomax Suits
Postby flying-i » Mon Jul 11, 2011 2:03 pm
For those that are interested you can contact Manny at Icarus Air Wear.
They make great products and will add pockets etc as you require. You can supply the nomax or they will supply.
Contact details:
Icarus Air Wear & Skydiving School
Tel: + 27 11 452 8858
Fax: 0865639108 or + 27 11 452 2101
083 252 8720
www.icarus.co.za
Jabbanaught
Re: Nomax Suits
Postby Jabbanaught » Mon Jul 11, 2011 2:09 pm
flying-i wrote:For those that are interested you can contact Manny at Icarus Air Wear.
Contact details:
083 252 8720
http://www.icarus.co.za
Thanks still wanted to add those details .
Suit appr R2200.00
Magni M22 - ZU EGA
Tinkerbell
Re: Nomax Suits
Postby Tinkerbell » Mon Jul 11, 2011 6:00 pm
What material is it made of? Is it flame retistant?
ZU-RKU Zen
ZU-RTM Calidus
Jabbanaught
Re: Nomax Suits
Postby Jabbanaught » Mon Jul 11, 2011 7:16 pm
Tinkerbell wrote:What material is it made of? Is it flame retistant?
Nomax , Affirm !!!
Magni M22 - ZU EGA
Grumpy
Re: Nomax Suits
Postby Grumpy » Mon Jul 11, 2011 10:34 pm
Do they all come with the 'Built in Boep' or is it just the model? :lol: :lol: :lol:
BONZAI BELL
Re: Nomax Suits
Postby BONZAI BELL » Tue Jul 12, 2011 7:20 am
No Grumpy , These suits are quite fancy. What you see there is a compartment for the helmet.
ZU-EOL
Magni M-22
braam hechter
Re: Nomax Suits
Postby braam hechter » Tue Jul 12, 2011 7:42 am
Good morning All.
Bonzai Bell, well said... Some people also think of everything.
Please remember that you have to take care of Nomex. Look at http://www.dpp-europe.com/plugins/fcked ... 002%20.pdf.
The important question is, can the Flame Retardant properties be removed?
No. NOMEX® is inherently flame resistant. This property cannot be degraded or diminished by processing. However, it is critical to remove greases, oily soils, and other flammable contaminants as they can burn independently and overwhelm the FR properties of the fabric. If home laundering does not provide adequate cleaning, professional care may be required.
NOMEX® Wash and Care guidelines
I Temperature and duration of washing and drying cycles:
• Fabrics made from 100% Nomex® brand fibre can be washed up to 95 degrees C.
• It is adequate to wash Nomex® garments at 60 degrees C. Using a higher temperature may not bring any benefit, and indeed may simply contribute to overall energy consumption. In addition, extended periods of physical agitation can cause fabric shrinkage, because the individual yarns
and fibres can become interlocked.
• The garment manufacturer may recommend washing at 40-60 degrees C due to other accessories such as reflective stripes, moisture membranes, etc.
• The washing cycle need not exceed 1 hour.
• Always include a rinse cycle that adequately removes residual soaps and detergents.
• At the end of the wash cycle, the alkaline pH environment is neutralized by addition of a dilute acid such as acetic acid.
• Drying can be done in either a tumble drier or a tunnel finisher.
• For tumble drying, outlet temperatures from the drum can be set up to 100C. The important factor in drying is not to over-dry. It is better to give the garments a shorter drying cycle and remove them while still slightly damp (up to 10% humidity by weight), than to remove them bone-dry. Again, this is because excessive agitation can cause localized damage such as abrasion and, in extreme cases, garment shrinkage.
• For tunnel finishing, air temperature should be set at 155C with an operating time of minimum 4 minutes. The load is considered to be dry when the load temperature (ie garment surface temperature) is 135-140C.
II pH of soaps and detergents:
• Avoid pH lower than 2 or higher than 12.
• The Nomex(R) brand fibre itself is resistant to all but the strongest acids and bases, with the rate of physical degradation being a function of concentration, temperature and duration of exposure to that extreme acidic or basic environment.
• Normally, avoidance of low pH agents is not an issue.
• High pH agents (range 10-12) may have an impact on the color of the garment, depending on the temperature/duration of exposure in this environment.
• Nomex® garments should never be subjected to strong oxidizing agents such as peroxides, hypochlorites or other chlorine-based bleaches. These can harm the physical strength of the Nomex® garments.
NOMEX® is a registered trademark of E.I. du Pont de Nemours and Company
Greetings and fly safe.
Braam Hechter
