Hi guys,
This is most probably going to be stupid questions, but need some answers:
1. If an aircraft is registred in the LSA category, will the hours flown on this aircraf by a PPL pilot count towards his COM licence or must the hours be on a registred light aircraft?
2. If I had a MPL licence that expired 5 years ago and I renew my licence according to all the required hours and tests............do I have a MPL or LSA licence?
3. Is there a difference between a MPL and a LSA licence?
Hope you guys can give me some clearance on this questions.
Jakes
PPL hours towards COM?
Re: PPL hours towards COM?
Hi Jakes..
Best thing to do is to chat with Willem at RAASA.
Here is some reading that might help you:
http://www.raasa.co.za/images/PDF/pilot ... ements.pdf
http://www.raasa.co.za/images/PDF/pilot ... gories.pdf
Give Willem a call on 011 082 1000 he will point you in the right direction.
Jaco P.
- Wargames
Hi Jakes,Jakes wrote:Hi guys,
Jakes
On #1: The hours count, as long you does not use a Z-type code. Phone CAA and ask for a alternative type code for that type to use for hour building purposes.
#2: That will depend on the weight of the aircraft. MAUW < 450kg -> MPL; MAUW < 600kg -> LSA
#3: Check answer above.
Phone Willem at raasa, although chances are good that he will refer you to CAA.
G0od luck.
Does Gyro plane hours count ?
Thank you Wargames and Pat Two!!!
Appreciate your help. Will talk to Willem if I can get hold of him
Jakes
Jakes
