Rotax 914 radiator pyping
THI
Postby THI » Fri Mar 18, 2011 3:24 pm
Where in the western cape can I buy radiator pyping for my rotax 914?
Thanks!
Thinus Enslin
Potchefstroom (FAPS)
ZU-CML
Would love a RV10 though...
Re: Rotax 914 radiator pyping
Postby Boet » Sat Mar 19, 2011 9:23 pm
Cape Rubber &Moulding Co , Belliville, or Midas. 1" univesal 90 deg bends available.
THI
Postby THI » Sun Mar 20, 2011 10:49 am
Boet wrote:Cape Rubber &Moulding Co , Belliville, or Midas. 1" univesal 90 deg bends available.
Dankie Boet!!
Thinus Enslin
ZU-CML
THI
Postby THI » Sun Mar 20, 2011 5:17 pm
Any comments on clamps?
Thinus Enslin
ZU-CML
Postby Boet » Wed Apr 06, 2011 8:26 am
I like to use good quality clamps, little bit more expensive, but wort it. And where you have to join 2 rubber pipes, I use 1' OD copper pipe. I made a nifty bead roller to roll the non slip beads on the water pipes. Works for me. (!!)
THI
Postby THI » Wed Apr 06, 2011 8:43 am
Dankie Boet!
Interessant...die pyp grote om die radiator en op my 914 se boonste inlet is 28mm, my onderste outlet op die 914 is 32mm :shock:
Is dit standaard?
Thinus Enslin
ZU-CML
Postby Boet » Wed Apr 06, 2011 9:19 am
Dis min af meer die norme. Bleddie ongemaklik.
Jabbanaught
Postby Jabbanaught » Wed Apr 06, 2011 11:28 am
THI wrote:Dankie Boet!
Is dit standaard?
Jy moet nou ophou plumber speel en begin vlieg jou verskoning raak OP ## ## ## ## ##
Autogyro - Calidus ZU- ???
Magni M22 - ZU EGA
