Jab Engines - the good and the bad?
cross_wind
Postby cross_wind » Tue Mar 15, 2011 8:09 am
Not to start a storm in a tea cup, but I was wondering if any of the pilots out there flying Jab engines are experiencing reliability or maintenance problems with their engines. I was planning on installing a 3300 in my CH750, but have been advised against it (by a few people and AMO's) due to reliability problems with the Jab engine. I also believe the European guys are having a lot of come backs on the 3300's. This is a HUGE concern to me as the Jab engine isn't cheap - for the same price I can go for the Rotax or Lycoming equivalent. So where does that leave the Builder/Sport Pilot? I had a look at the Revmaster (thanks Phil for the tip), and it does look good, but the 750 has a MTOW of over 600kg. Add to that the density altitude up here and I would prefer having over 100 hp making noise up front. :|
Cross_Wind
Challenger II LS ZU-FCP
justin.schoeman
Re: Jab Engines - the good and the bad?
Postby justin.schoeman » Tue Mar 15, 2011 10:15 am
I haven't owned one, but I have 120 hours behind other people's Jabis, and I would not hesitate about flying behind another. If they are maintained well, and set up exactly according to the Jabiru installation manual, then they are very reliable.
They are also substantially cheaper than Rotax to by and maintain.
Mc Guyver
Postby Mc Guyver » Tue Mar 15, 2011 10:22 am
cross_wind
Postby cross_wind » Tue Mar 15, 2011 10:28 am
mmmm - hope the pilot is ok.
Cross_Wind
Dobbs
Postby Dobbs » Wed Mar 16, 2011 9:12 pm
I have minimal time on a Jab powered powered plane, but know enough people who own and fly them and my understanding is that they are no more or less reliable than a Rotax / Lycoming etc.
I also know of a Jab owner whose plane has had two forced landings and one incident, and it was fuel starvation, read tanks full of air, prop departed aircraft and pilot aborted takeoff and put the aircraft down hard damaging the undercarriage, and none of the above involved an engine related problem.
There are many of the I heard from his best friend who knows someone ......... stories ($$)
Has this AMO got personal experience with poor reliability Jab engines.
If the engine is being used for the purpose for which it was designed, and being cared for as per the owners manual, you can't go wrong with a Jab or any other equivalent engine.
Dish
Postby Dish » Thu Mar 17, 2011 9:25 am
In the words of the well known and highly respected Kevin Hopper "fuel it, cool it and lube it, and it will run forever" - havent heard a bad word about a jabi' engine, know first had of 2 engine outs both fuel related, one resulted in a LOB and the other, simply restarted and carried on flying... (cautiously of course)...
RV9
DISH
KFA
Postby KFA » Thu Mar 17, 2011 8:31 pm
600 training hours on our school one.No hassels. 2200 85hp engine. Needless to say, my next explorer will have a Jabi in again. Reliable, cheap to maintain and good value for money.
Postby John Boucher » Tue Mar 29, 2011 7:50 am
I AM going to put a Jab 3300 up front in the Cheetah one day... there are engines that are not up to scratch and none of them have been mentioned here.
Most comments iro of maintaining an engine holds true - if you look after it, it'll look after you!
I personally think the Jab engine is a by far cheaper and less complex engine to maintain. If you get the cooling, fuelling & oiling right... then what's left?
JuanMarais
Postby JuanMarais » Tue Mar 29, 2011 10:04 am
Will there be a big different between the Jab 2200 and the Rotax 912ULS in the Explorer? Im talking like is it worth spending the extra money for the little bit more power?
Bushbaby Explorer : ZU-FYJ
cross_wind
Postby cross_wind » Tue Mar 29, 2011 10:10 am
Don't think you can make that comparison. Jabiru 3300 and Rotax 912S sure.
Cross_Wind
JuanMarais
Postby JuanMarais » Tue Mar 29, 2011 10:48 am
Ja ok, if you look at the bigger ones. What does the Jab 2200 compare to against Rotax. Im quite new to this field and just bought an Explorer kit. Still not sure what engine to fit...
Postby John Boucher » Tue Mar 29, 2011 10:50 am
I think a Jab 3300 is way cheaper than a complete packaged Rotax 912ULS....
cross_wind
Postby cross_wind » Tue Mar 29, 2011 10:52 am
JuanMarais wrote:Ja ok, if you look at the bigger ones. What does the Jab 2200 compare to against Rotax. Im quite new to this field and just bought an Explorer kit. Still not sure what engine to fit...
I am having the same problem.
Cross_Wind
JvTonder
Postby JvTonder » Tue Mar 29, 2011 1:17 pm
I have a BushBaby with Rotax 912 and it flies great but have flown with Stefan in the factory Explorer with the Jab 2200, also great! I say buy what you can afford!
Flying feeds the soul!
cross_wind
Postby cross_wind » Tue Mar 29, 2011 1:22 pm
The real issue here is the Jab isn't a cheap option anymore. Last quote I got for a 3300 was R 138,000. Pretty close to a 912.
Cross_Wind
