Oil presure Rotax 912ULS
Johan Nortje
Postby Johan Nortje » Tue Feb 22, 2011 4:57 pm
Is there someone that can give me guidance. I have the following problem with my Rotax 912 ULS.
Ad normal operating revs 4900rpm the oil pressure is 65 - 70 psi. Sins last week for some reason the oil pressure "jump" to 90 - 110 psi for max. 5 seconds and then back to normal for +- 5 min, and then up again for 5 seconds etc etc.
What is the reason for this, and is it harmfull to the engine.
The engine has done only 180 hours. I have a MGL oil pressure gauge.
I have already replace the oil and oil filter, and and the problem still exist, at 1800 rpm.
Please help me.
MAGNIficent
Re: Oil presure Rotax 912ULS
Postby MAGNIficent » Tue Feb 22, 2011 6:10 pm
This might be your Oil Pressure Sender - VDO or the pressure relief ball and spring.
To fly is LIFE...!!!
Keep on LIVING...!!
Johan Nortje
Postby Johan Nortje » Tue Feb 22, 2011 10:11 pm
Thanks, I will replace the VDO tomorrow. I have allready clean the ball and spring.
Postby Morph » Wed Feb 23, 2011 2:58 pm
Comet sell a fix for the ball and spring, part 100857230, Oil Pressure Control Valve, about R180. replaces the ball and string. I am thinking of moving my VDO off the engine and mounting it on the firewall, with a flexible rubber tube connecting it to the engine. I replaced two VDO sendors in 100 hours :twisted:
Dobbs
Postby Dobbs » Thu Feb 24, 2011 7:04 pm
Agree with Morph, I am on my third VDO sender in 500 hrs, next one will go on the fire wall.
I enquired about an electronic alternative which is available, and even these are not trouble free.
MADDOG
Postby MADDOG » Fri Feb 25, 2011 12:16 pm
In my experience, the capillary tube gauges are more reliable but make sure you protect the capillary tube.
Aquilla the Hun
