Hi,can anyone please explain how you balance a 3 blade propeller
thanks
max
Balancing of 3 Blade Propeller
- First solo
Re: Balancing of 3 Blade Propeller
viewtopic.php?f=13&t=4621
this describes a two blade, but it is the same for a 3 blade. when the prop is hanging horizontal, the highest blade is the lightest. Add weight to this one using laquer, and continue until the prop hangs flat.
- First solo
thanks morph
regards
max
regards
max
