Flying a Bushbaby with the doors off
I want to fly my Bushbaby with both doors removed, is it safe to do so?
Re: Flying a Bushbaby with the doors off
Yes, but there is a speed restriction. IIRC it 75mph?
Great, Tx G
Enjoy, but maybe give Stefan or Rick a ring just to confirm....
Stefan - +27 82 601 897 oh
Rick - +27 82 41oh 0032
- KFA
You can open the door in flight, no need to leave them on the ground. Max 90mph but you will find with both doors off that the wind will bother. With a right hand tractor config you will find that the left side has less wind and works great. Just watch your ASI and VSI. If you do not have a static source outside the plane they will give you erratic readings. Enjoy
Rather open them, but do limit speed to round about 70mph.
Sien ek het geluister toe ek konvex gekry het...Boet wrote:Rather open them, but do limit speed to round about 70mph.
- thys bas
- I hate bird strikes
What does the open door do to the fuel consumption? Does the open door create more drag? Is it advisable to fly with door open for long distances?
Owias it is much nicer and cooler
IIRC fuel burn is slightly higher and speed is lower... but you would not drive long distance with doors off. it gets tiring after a while. On Ferry from CT to Jhb I flew for stretches with door open (heat in Kalahari was 45+), but it gets tiring.
- KFA
To answer. Higer fuel burn because of more drag and
Just to confirm the speeds Max is 90mph. Recommended is 70-80. Not under 70 when doing turns and so on and do observe the ASI and VSI errors.
depends how quick you want to get to your destination.Is it advisable to fly with door open for long distances
Thanks for the info guys
I just want to fly around the patch a little and enjoy the fresh summer breeze
will keep the max airspeeds in mind.
I take the doors off, because if you fly in Xwinds sometimes the doors "flap" or fly at half mast and can distract enough to cause a problem... (like stall while trying to hold open or close...
Where the hell is your hurry to when you are flying for fun anyway?? Is`nt the aim to stay airborne for as long as possible...??KFA wrote:To answer. Higer fuel burn because of more drag anddepends how quick you want to get to your destination.Is it advisable to fly with door open for long distances
Not everyone fly's for fun Some oukes want to get places....
