Skin
I am not fimiliar with the glass type, just make sure that it does not use the paper type element as it might block the oil and only let the fuel through, except if your 582 have oil injection installed.lefssa wrote:Anyone use the glass type filter. the one that can be taken apart and cleaned.
All Airborne trikes in Oz use the glass filters.lefssa wrote:Anyone use the glass type filter. the one that can be taken apart and cleaned.
There have been many heated discussions regarding this filter and I for one, had an engine out directly related to it, and it had been cleaned 5 hours before that. The mesh is too fine, .1 as opposed to 0.3mm and clogs up very quicklylefssa wrote:Anyone use the glass type filter. the one that can be taken apart and cleaned.
Can you have a look on the filter and see if it states the country of mfg.lefssa wrote:There if obviously a problem with these filters. a an going to remove mine and maybe we should advise other people that have these filters to replace them.
