PROPELLOR ADVICE PLEASE
BOOMARANG
Survived first engine out
Postby BOOMARANG » Sun Aug 15, 2010 8:59 pm
During a pre-flight inspection I noticed a hairline crack near the base of one of the three blades of my warp drive. I need to make a decision on replacing or possibly repairing the blade. Any advice on the following please:
1. Can the blade be repaired? i.e a crack cut out and welded up again. The crack is in the aluminium part where the blade meets the hub. If so, does anyone have any contact numbers?
2. I see on the Comet Aviation website that the blades can be bought seperately. The current warp drive has 42 hours on it. Can one now fit a new blade and what about the difference in hours.
3. As the blade is virtually brand new without even a nick on it, the crack is clearly a factory fault, what recourse do I have to claim it from the manufacturer?
4. What wooden prop would be advisable for an Aquilla with a 582 and a 3,47 E-box should I choose to go that route?
Any help and advice would be appreciated
Cor 0798848927
BOOMARANG
Re: PROPELLOR ADVICE PLEASE
Postby Boet » Mon Aug 16, 2010 9:08 pm
P-prop would be a RIGHT HAND TRACTOR 72" x 52" . I hope you are not FLYING with that WD. When it cracs there, use it for a beach cricket bat. It is NOT repairable.
kloot piloot
Postby kloot piloot » Tue Aug 17, 2010 7:16 pm
viewtopic.php?f=16&t=13272
The recent topic above covered something similar.
I do not see why the supplier / manufacturer will not be able to investigate and replace. At least not with only 42 hours and if installed according to manufacturers' specs.
Keep us posted. vhpy
Roel Jansen
ZU-IAR powered by BMW 1200
