Where can I get pop out fuses? Are they called pop out fuses?
Thx!
Pop Out Fuse
- THI
Pop Out Fuse
Thinus Enslin
Potchefstroom (FAPS)
ZU-CML
Would love a RV10 though...
ZU-CML
- clive layland
- Pre flight checks done
Re: Pop Out Fuse
Thinus
Are you refering to Circuit breakers rather?
You can get these from Aircraft Spruce, or order locally through Placo.
http://www.aircraftspruce.com/menus/el/ ... akers.html
http://www.placo.co.za/index.php?option ... &Itemid=36
The Klixon are the push pull type which are a little pricey @ $22 each, but they work well.
Re: Pop Out Fuse
Considering that they are reusable, it's worth it, especially when far away from a Midas
Looks nice too
Looks nice too
- THI
Re: Pop Out Fuse
Any idea of what these fuses / circuit breakers will cost locally?
Thinus Enslin
ZU-CML
ZU-CML
- clive layland
Re: Pop Out Fuse
Phone Placo, they will be able to quote you.
Assume they will add tax, import duties(if they apply) and mark up, so you are most likely looking at around R220 to R250 each
- Lieb Liebenberg
- Passed radio course
- THI
Re: Pop Out Fuse
No way!!clive layland wrote:Phone Placo, they will be able to quote you.
Thinus Enslin
ZU-CML
ZU-CML
Re: Pop Out Fuse
CB's look very professional, but are VERY expensive. For the average micro/light aircraft, rather use the normal glass fuses. Always have some spare fuses in your flight bag.
Remember, if a CB pops, or the fuse blows, DO NOT just reset the CB, or replace the fuse!! There is a reason for the interruption in the circuit. FIND THE PROBLEM.
The latest trend in airliners is that if the CB pops, don't even try to do a reset, specially in the air, and a reset should only be considered if the equipment is of vital importance. For us flying in VFR conditions, resetting a CB/changing a fuse in the air can be expensive, and outright dangerous.
Think twice, do once....
Christo J/v Rensburg
"To be legal, you need the law;
To be just, you need a value system"
- THI
Re: Pop Out Fuse
You are reading my mind! Why reset if it pop the first time. Land and inspect...and much cheaper!ZAZU wrote:CB's look very professional, but are VERY expensive. For the average micro/light aircraft, rather use the normal glass fuses. Always have some spare fuses in your flight bag.
The latest trend in airliners is that if the CB pops, don't even try to do a reset, specially in the air, and a reset should only be considered if the equipment is on vital importance. For us flying in VFR conditions, resetting a CD/changing a fuse in the air can be expensive, and outright dangerous.
...still...can I cut buget if I'm up in the air...?
Thinus Enslin
ZU-CML
ZU-CML
Re: Pop Out Fuse
Morph wrote:Considering that they are reusable, it's worth it, especially when far away from a Midas
Looks nice too
- Stephan van Tonder
Re: Pop Out Fuse
or you can get them here RS Online [RSOnline.za@online.rs-components.com]
look for resetabble fuses and for the rating and voltage you want.
- THI
Re: Pop Out Fuse
Thanks for the info, but this is what i got..Stephan van Tonder wrote:or you can get them here RS Online [RSOnline.za@online.rs-components.com]
- resettable fuses.jpg (5.21 KiB) Viewed 2873 times
Thinus Enslin
ZU-CML
ZU-CML
