Authority to fly
Authority to fly
can anyone tel me if there is a checlist of things that needs to be checked by the AP in order to provide an authority to fly certificate
- KFA
Re: Authority to fly
Are you talking about an inspection checklist for your aircraft or the paperwork for raasa? For RAASA you will need the two forms attached and for your plane you will have to contact the manufacturer for the inspection checlist and SB's
- Renewal ATF.pdf
- (37.3 KiB) Downloaded 306 times
- Annual Inspection.pdf
- (42.21 KiB) Downloaded 184 times
thanks I am looking for the checklist to understand what the AP must check in order give the tumbs up.
- KFA
If for a trike, I can send you a general one. If for three axis then you must contact the manufacturer or distributor directly for their maintenance checklist.
I got one from MISASA or RAASA, not sure.
but it is good enough
- Weight shift inspection checklist.pdf
- (48.28 KiB) Downloaded 455 times
thanks a lot. just what i was looking for
