where can i buy a steering damper for a trike? New or used ? Any idea of the cost? How much will a damper help for the stability of the frontwheel on the landing? Provided the wheel is correctly inflated at 0.9 bar?
steering damper for trike frontwheel?
Re: steering damper for trike frontwheel?
Any bike shop should supply them. You will have to fashion your own brackets though
Morph wrote:Any bike shop should supply them. You will have to fashion your own brackets though
Maybe give these oke's a buzz.
http://www.gorillazillaproducts.com
They manufacture steering dampers and brackets, and could possibly build you a mounting?
Most trike problems are caused by the nut that connects the seat to the handlebars!
