Pilot induced oscillation on a trike
Big-D
Postby Big-D » Wed Apr 28, 2010 3:46 pm
As per a previous post, and at Wargames' request a quick discussion about Pilot Induced Oscillation
I have only ever really experienced PIO on an Airborne trike and let me tell you this is quite scary and you could quite easily loose control completely :shock:
When I did my conversion onto Airborne the instructor (Larry Eschner) told me to build up some speed and put the plane into a steepish bank, not a radical manouvre at all, just a medium fast turn - What resulted was that the plane started veering quite violently from side to side :shock: Now I can almost bench press the weight of an empty trike but I did not have the strength to bring the wing under control and things were getting completely out of hand :shock:
The oscilating just became worse the more I tried to control it untill the instructor told me to let go of the wing completely - As I let go of the wing it recovered almost immediately.
The name says it all, it is PILOT INDUCED - Before flying the Airborne I had approxamatly 200 hours experience on Aquila, Safari, Mainair Gemini, Air Creation - I flew the Airborne trike the same way I would fly the others, on the Airborne I tended to over compensate which causes the oscilating I guess
This is a common occurence for people flying the Airborne for the first time and for this very reason Larry Eschner warned me under no uncertain terms to not even consider trying to fly my Airborne without a Airborne rated instructor the first time.
As for the physics behind it - I am not sure, could be my imagination but I think an Airborne's wing is "higher" - Meaning further away from the undercarridge. It looks that way - I could be completely wrong
Anyhow, anyone reading this - I am not saying anything bad about Airborne, just stating that the PIO is not to be messed with without the knowledge of how to recover: - "just letting the wing go when it starts oscilating" - As bizarre as that sounds, it works
After a few hours on AIrborne it never oscilated with me again, telling me that is just flies differently to other trikes and once I mastered the wing I had no problems.
D
Big D
Re: Pilot induced oscillation on a trike
Postby nicow » Wed Apr 28, 2010 4:35 pm
It sounds like a stall to me... :?:
Biggles
Postby Biggles » Wed Apr 28, 2010 5:22 pm
Some questions:
What were you doing when it started ocillating? Just turning or maintaining a steady rate turn with left and right inputs?
Does the trike in question have wheel spats with winglets? I am highly suspicious of these winglets because if the undercarriage is not dead into the airflow they will aerodynamically effect the handling. Especially as you can change the "heading" of the undercarriage independent of the wing by twisting the bar (yaw). So imagine you are in a fast turn and the pilot is twisting the wing the winglets might not be dead onto the airflow. The winglets will cause a fishtailing type effect with the undercarriage winging, with johnny pilot making it worse by twisting the undercarriage as he tries to settle the whole thing down. Releasing the wing will mean that the whole shebang will settle down again.
Trike pilot
ZU-DLP
Winelands FAWN
Biggles
Postby Biggles » Wed Apr 28, 2010 5:26 pm
Was the wing in the neutral position in the turn? And releasing the wing allowed to to move to the neutral position?
Trike pilot
ZU-DLP
Winelands FAWN
Wargames
Postby Wargames » Wed Apr 28, 2010 6:10 pm
Big D,
Thanks for the explanation. I will go and think about it for a while. Interesting situation though.
Dirk
Postby John Boucher » Wed Apr 28, 2010 8:11 pm
I'm no boffin at this and I am sure the men with the big hats on this forum like Ducky etc. will give their input.
My logic says it's like a motorcycle getting a speed wobble or a serious tank slap and the more you as rider tries to rectify the situation the worse it gets (thus some models of bikes came out with a steering damper. The rake angle of the front fork obviously the reason. The Suzuki TL1000R had one and I know because I owned one and experienced the bitch first hand powering out of a turn to hard) I think your reaction time to the problem is just that fraction too slow and then applied too much too late. The result is you stand up, take your hands off and change the COG and voila...
But a trike is hardly a motorcycle....
Postby Blue Max » Thu Apr 29, 2010 10:10 pm
:mrgreen: Sorry gents. I am try-ing hard to understand this one.
Can some-one plse explain this to me in Afrikaans.. puff puff
I try to praat your Thaal.!!!
Mc Guyver
Postby Mc Guyver » Fri Apr 30, 2010 1:22 pm
[quote="Big D"]As per a previous post, and at Wargames' request a quick discussion about Pilot Induced Oscillation
Many people wind in the luff lines for take off and landing.
This alters the reflex dramatically.
The only time I would do this is when flying straight and level with slower trikes or if I need to reduce my airspeed for any other reason.
I certainly do not allow students/pilots to do this for landings or take off.
What also needs to be done is to release the trim completely.
The ferrule should disapear into the tube and not remain between the slow and fast indicators.
Please try this and then if you can report back on the handling.
Big-D
Postby Big-D » Fri Apr 30, 2010 5:11 pm
Ok, from the top: vhpy
Nope, far from it
Important point: This particular airborne cruises at 52 knots, I was doing close to 60 knots, went into steepish left bank, once the level of bank was obtained I wanted I countered by moving the bar to neutral - THis is when the trike started oscilating, and all of a sudden banked sharply right, then sharply left, then sharply righ - I lost control - Untill instructor told me to let go of wing completely - Recovered immediately
Edge X - Normal spats
Nope, this is what starts the oscilation - If you fly the Airborne like an Aquilla or Mainair in my experiecne it will oscilate - I was going into left bank and then moved bar towards right to get it back to neutral in order to maintain bank - This is when it started oscilating - What I should have done is given smaller pilot inputs, but you only learn this after an hour or 2 on the Airborne
Ja, something like that except that this "tank slap" gets progressively worse :shock: Forget the Suzuki's and get a BMW John - A real bike vhpy
Dis heel eenvoudig: Ek het in 'n vinnige links-om draai gegaan, toe ek tevrede is dis ver genoeg gedraai toe bring ek die bar terug neutral toe, terwyl ek steeds in die draai was - Met die aksie het die trike na regs begin draai, ek probeer toe kompenseer en toe gaan ons weer links, weer probeer kompenseer toe gaan ons regs - So het dit erger en erger geword totdat ek feitlik beheer verloor het - Toe ek die vlerk heeltemal laat gaan op instrukteur se instruksie toe hou dit dadelik op en sy vlieg pragtig
Good point, in my case though I did not role up luff lines at all, cable was interely loose
D
Big D
Postby Duck Rogers » Fri Apr 30, 2010 10:47 pm
John Boucher wrote:I'm no boffin at this and I am sure the men with the big hats on this forum like Ducky etc. will give their input.
Sorry.........I'm an observer on this one. I know nothing about trikes or PIO, I fly a real aeroplane...... :twisted: :twisted: :twisted:
Postby John Boucher » Sat May 01, 2010 9:57 pm
And there Ducky goes and disappoints me and Big D.... I finally had a BMW bike but due to Aviation Induced Divorce Syndrome I had to relinquish my ownership!
Big-D
Postby Big-D » Sun May 02, 2010 10:10 am
Eish :( You will have one again Johno
Big D
