Hi guys
Going to CTrubbers just now and would like to buy fuel tubing as well as the vent line from tank and between carbs (the hard see through pipe)
Any idea what the two diameters are? Forgot my samples at home.
fuel tubing size
fuel tubing size
Take to the sky
ZU-CBI
Aerotrike Scout
ZU-CBI
Aerotrike Scout
Re: fuel tubing size
Normally internal diameter of 6mm. I use high pressure fuel injection hose available from any Midas. You don't need the see through line
Thanks Morph
Any idea what the vent line on carbs are. Think they are 3mm - about halve the main lines. The ones that needs slots cut in them in oorder for the carbs to function.
Take to the sky
ZU-CBI
Aerotrike Scout
ZU-CBI
Aerotrike Scout
Not sure, and yes you have to have the slots cut in them
Rubber and Mouldings will definitely have this tubing,
- bluesmancoops
Karl are you flying again?
Mike Cooper
Hi ya Mike
Not yet. But almost! Busy with a trike again. Going to be in my garage for a couple of weeks still. Ready for the nice winter flying.
Karl
Karl
Take to the sky
ZU-CBI
Aerotrike Scout
ZU-CBI
Aerotrike Scout
