ANCHOR-PINS FOR STRONG WINDS WHEN PARKED
I'm searhing for a idea to anchor my trike when the wind is realy strong and no hangerage is available,the normal v-shaped big tentpins is not sufficient in such strong winds,any ideas?
- KFA
Re: ANCHOR-PINS FOR STRONG WINDS WHEN PARKED
There is a gadget at aviation engines. It's a three way claw that you hammer in the ground. Works very well. The more you pull on it the tighter the grip.
http://www.cometaviationsupplies.co.za/ ... ie%20Downs
I simply use more tent pegs. If you use 3 (like claw) per rope then it a MOERSE wind....
- Tumbleweed
With tent pegs, if the ground's too soft they just pull out and if the ground's too hard or rocky you can't hit them in. Get the claw (expensive) or copy. Better than spending the night clinging to the bar wishing you spent a bit more.
Claw uses same tent peg type "pegs".. The sand or storm pegs (v shape) work very well in most condition. Obviously if you cant get it into the ground you stuffed, but so is the claw...
Re: ANCHOR-PEGS FOR STRONG WINDS WHEN PARKED
Thanx for the advice ,the claw looks like something i could use instead of tent-pegs(pins)my translation from afrikaans to soutietaal is not so lekka thats why i called it pins(penne).
- Tumbleweed
Claw
- Claw.jpg (47.83 KiB) Viewed 1636 times
R1511 at Comet.
Point is 3 v pegs in triangle arrangement does exactly same thing....
And I will give you the pegs for free, you just pay postage.Just to help the microlighters out.
Morph posted a great diagram on how they should be used.
Tent pegs are fine but I got tired of battling to get them into hard ground. They bend.
I got the claw as shown above and its a winner. Goes into anything and will never come loose. I bit expensive but if you can get them you will not look back.
ZU - forePLaY
ZU - forePLaY
I rekon given some engineer thought you could make a "CLAW" with 9 inch nails. Theory is to counteract the force of the rope. the nails go in easily. I have seen some huge ones at the camp shops with a big flat head that go into anything. All you then need is a base plate of some sort to spread the load with eye in middle for the rope...
Easier to buy the claw, but more fun to make your own....
