CHT \ EGT TEMPERATURE RANGE ON 503 SI DC
falconp1
Postby falconp1 » Wed Mar 03, 2010 12:49 pm
Hi Guys.
Im about to install an egt guage and sensors to my airy. Its a 503 si dc. Can anybody tell me what temp it should be running at for cruise and takeoff. The same question for the cht. Any response appriciated.
No I cant RTFM because i did not get one vhpy
ZS-WVD CONDOR
ZU-CIW Challenger 11
freddievanrooyen@yahoo.com
Re: CHT \ EGT TEMPERATURE RANGE ON 503 SI DC
Postby Morph » Wed Mar 03, 2010 3:33 pm
CHT Max 250
normal 180 to 220
EGT max 650
normal 460-580
all temps in deg C
EGT is the big one you watch while flying. It is related to the richness of the oil in the fuel
EGT High - Lean, lower oil in the fuel - bad
EGT low - Rich, higher oil content, better for cooling and lubricating the motor.
You should be able to take off at full throttle, 6400rpm and the EGT's should remain quite cool. As you tap off to cruise you could see the egt's increase as the fuel/oil leans a little. As long as they are in the normal operating zone you are safe.
falconp1
Postby falconp1 » Wed Mar 03, 2010 4:02 pm
You young man are a fountain of information.
THANKS Morph. (^^)
ZS-WVD CONDOR
AndyG
Postby AndyG » Thu Mar 04, 2010 7:42 am
falconp1 wrote:You young man are a fountain of information.
THANKS Morph. (^^)
I have seen lots of technical questions pop up here and more often than not it is Morph who posts the answers. (^^)
Postby Tailspin » Tue Mar 09, 2010 9:46 am
THANKS Morph. (^^)
YIP
Morph is the main Guru when you ask anything technical there is about an 90% chance Morph will answer unless he is Busy.
Postby Morph » Tue Mar 09, 2010 10:01 am
No I just happen to have the manuals
AndyG
Postby AndyG » Tue Mar 09, 2010 12:29 pm
Morph wrote:No I just happen to have the manuals
The point is that you take the effort to dig out the answers and help the guys
Postby Tailspin » Tue Mar 09, 2010 1:25 pm
Spot on Dude :!: :!: :!: :!:
