AERIAL LOST!! ??
HENNING JOHAN
AERIAL LOST!! ??
Postby HENNING JOHAN » Sat Jan 16, 2010 5:10 pm
This morning I lost the aerial wire. :roll: We did a power off stall and after the stall saw that my aerial wire is on my lap. :shock: Just before the stall we(me and instructor) made a radio call but it broke up.I ask Porra to give me the radios atenna that was in the panierbag.We return to the circus airfield and refitted the wire. (^^) After refitting and refuel we did circuits and the radio was fine.I supose the grap screw come loss.For safety can i glue the wire so it doesn't come off again?FLY SAFE!!FLYBOY OBD (!!)
Re: AERIAL LOST!! ??
Postby Duck Rogers » Sat Jan 16, 2010 8:01 pm
Of course you can glue it in. Just make sure that all connections are sound and are making good contact because you never gonna get it out again vhpy
HENNING JOHAN
Postby HENNING JOHAN » Sat Jan 16, 2010 10:15 pm
Thanks,Duck Roger!What glue can I use?Pratley steel?I just want to put it where the wire stick in to the hole on top.FLY SAFE!!FLYBOY OBD (!!)
Postby Duck Rogers » Sat Jan 16, 2010 11:11 pm
Johan, Pratley Steel is ok, maar jy MOET seker maak daai grubscrew is in en hy's vas en die dinge konnekteer met mekaar
Postby Tailspin » Mon Jan 18, 2010 8:21 am
HENNING JOHAN wrote:Thanks,Duck Roger!What glue can I use?Pratley steel?I just want to put it where the wire stick in to the hole on top.FLY SAFE!!FLYBOY OBD (!!)
HI Johan
Take some pratley steel and put the wire in then put just a smear on the grub screw that you have turned out completely, you turn it back in and make sure all is corrrect in place cos it will not come loose again. ## ##
I did that and well even after i hit the deck the aerial was still in place :oops:
If you need to take it out you just heat up the whole unit and it will eventually brake free.
Just a suggestion. Worth a try.
Kingfisher
Postby Kingfisher » Mon Jan 18, 2010 5:34 pm
Johan, maak net seker dat jy elektriese verbinding het tussen die veer en die whip nadat die gom droog is, anders gaan jy baie swak kommunikasie hê. Dieselfde as sonder die whip. Jy kan ook loctite gebruik. As jy dit nie nagaan nie kan jy jou transmitter transistor uitbrand wat 'n stywe paar rand kan kos om te herstel. Die totale lengte van die antenna behoort 600mm te wees wat jou 'n 1/4 golf lengte gee op 125 mHz. Hoop dit help.
Hulle maak deesdae die vere met twee grubscrews wat baie help.
