Weber Carb conversion
flykr
Postby flykr » Mon Oct 05, 2009 11:27 am
Can a Weber DCOE side draught carb be used on an aircraft auto conversion?
I have heard that if the carbs are tilted beyond 25 degrees they will flood the engine - is this true?
Engine in question is a Honda 16valve, the current set-up is not ideal and uses a 32mm Ellison Throttle body and I'm looking at improving the set-up if possible. :)
