How do you loosen tyres from aluminium rims?
alan
Postby alan » Sat Sep 12, 2009 6:02 pm
Does anyone have any experience in getting off trike tyres that are stuck to the rim? The rubber and the aluminium seem to fuse. I took them down to the local tyre place eventually. They removed the tires but now I need new rims :shock:
There may be a trick to do this.......
Waiting for the wind to stop
Graham Mac
Re: How do you loosen tyres from aluminium rims?
Postby Graham Mac » Sat Sep 12, 2009 8:12 pm
tyre levers and lots of soap water...carefull not to PINCH tne tube...
of a soaring bird
nickjaxe
Postby nickjaxe » Sat Sep 12, 2009 9:49 pm
Well on my old Landrover I have a tool that has a chisel end but rounded off, all tyres fitters have these and you bash it with a hammer between the tyre and the rim with soapy water to help lube the job, going around the wheel a bit at a time,
I would think the much lighter wheel/tyre of a micro would be the same but very much scaled down in force needed.
Nick.
Postby Boet » Sat Sep 12, 2009 10:27 pm
Nice bench-vice and lots of patience= no damage. (!!)
alan
Postby alan » Sun Sep 13, 2009 10:13 pm
Thanks will get my wife's sunlight soap out and see if it works :wink:
Hermanator
Postby Hermanator » Mon Sep 14, 2009 1:34 pm
You are trying to break the bead seating. We have this often on the bikes. One of the easiest ways to remove the bike tyre is to use the side-stand and the bikes weight to lever the tyre down and break the bead. Alternatively, we have used the backup vehicle to drive over the tyre which also breaks the bead. Of course, that's a delicate job and relies on accuracy of your spotter, but it does work and is effortless.
It's a risky think using hammers and chisels as the chance of either denting or buckling the rim could render the wheel US.
Lawrence
STARCOM SA The worlds finest communications system - www.starcom1.co.za
021-461-1440 or o768355923
alan
Postby alan » Wed Sep 16, 2009 1:34 pm
Thanks for all the advice. It worked. Lots of patience, sunlight soap and much grunting. Once the bead has moved then it seems to go OK but that was the hardest part in getting the tyre bead to move on the rim. Very careful in doing this as the rim can easily bend or the tyre tears.
Thanks again vhpy
Z-MRP
Postby Z-MRP » Wed Sep 16, 2009 4:11 pm
Theres no plan here, if you dont have a mini tyre press you will destroy the rims. The best place to take your rims to is a Karting Shop, they use ali rims and will have this tool to remove your tyres. Pay attention when you at the karting shop,take pic of tool with cell phone, as this tool is so simple to make.
alan
Postby alan » Wed Sep 16, 2009 8:09 pm
We live in the backwoods of Grahamstown, only carts here are the ones at Checkers :lol:
Maybe someone can take some photos. I used two flat sided pieces of steel I ground and smoothed out as levers. Quite simple really once I had struggled a bit.
priester
Postby priester » Sun Sep 20, 2009 8:46 am
Spookpis
