Hi All..
Starting a new project in Port Elizabeth..
After long consideration, two of us, Kallie Venter and I (Jacques van Wyk), decided to test our friendship, marriages, patience etc.. and take the plunge..
Tail kit and plans on order from Bundu Avaition...
Zenith CH750 STOL (P.E.)
Re: Zenith CH750 STOL (P.E.)
Good luck guys....I also bought my kit through Bundu and thus removed all the importation nonsense that would have resulted otherwise. Now the wait for the kit will probably kill you!
Great to hear you guys have taken the plunge. I'm busy scratchbuilding a 650 (very slowly). Currently I spend quite a bit of time away from PE. Mike Hubsch in PE is busy with a 801. Should make contact with him 083 six one one six zero 44. You went the wise route working through Bundu. You will get all the suppurt plus from Philip.
Thanks for the good wishes guys.. We (PE guys) should get together sometime and share ides and experiences.. Apparently there's anothe 801 builder in Sedgefield...
Well keep you posted...
- Pre flight checks done
Waiting for tailsection so started scratchbuilding slots and Flaperons had lots of fun
- Slat ribb
- Image0319.jpg (22.17 KiB) Viewed 4917 times
- slat connection plate
- Image0320.jpg (14.41 KiB) Viewed 4917 times
- L bracket foir stiffness
- Image0322.jpg (15.91 KiB) Viewed 4917 times
- slat rib with attachment plate
- Image0324.jpg (21.12 KiB) Viewed 4917 times
- slat rib attached to slat skin
- Image0325.jpg (27.05 KiB) Viewed 4917 times
- inside of the above
- Image0326.jpg (22.15 KiB) Viewed 4917 times
- riviting
- Image0327.jpg (16.25 KiB) Viewed 4917 times
- end rib
- Image0328.jpg (20.83 KiB) Viewed 4917 times
- before closing the skin
- Image0329.jpg (30.82 KiB) Viewed 4917 times
- skin closed with view from inside
- Image0330.jpg (23.58 KiB) Viewed 4917 times
4 solo flights builds character
Looking good guys!!! When can I pop around and introduce myself & see what you are up to?
Good choice of aircraft crashtest! Are participating in the seven day build with Philip in late May early June?
Will be there cant wait to see how the pros do it and to steal with the eyes
Kallie
Kallie
Look forward to meeting you there!
- cross_wind
- Got my wings at last
Any more updates? Just wondering to the status of the 750's out there. I think Andrew Conroy's (built by Phil @ Bundu) will be the first one flying. The race is on!!
Cross_Wind
Challenger II LS ZU-FCP
Not if you keep going at the rate you currently are...my bets are on you as Philip's workshop is busy busy!
- cross_wind
Hah! I may get divorced if I don't slow down. I have posted some updates on my thread..
Cross_Wind
