Where to buy fuel system fittings and throttle cables?
justin.schoeman
Postby justin.schoeman » Fri Aug 07, 2009 12:36 pm
OK - If I intend to get the engine running once I have finished the rebuild, I will need to get the fuel system and throttles finished...
I still need to find a finger strainer (to go in the tank), and the fittings to hook it all up. Any idea where to get these, or should I just order from Aircraft Spruce? (OR, would a fuel petcock assembly from a motorbike tank work?)
Also need to get bowden cables and fittings to put together the throttle system? Any local suppliers?
Any other hints as to general supplies, and where to get them?
Thanks!
Justin
PS: I am in Pretoria, so local suppliers, or places that do deliveries are best!
Splinter
Re: Where to buy fuel system fittings and throttle cables?
Postby Splinter » Fri Aug 07, 2009 4:08 pm
If you want to build your own throttle cables try Rono Services in Springs. They sell the cable and sleeves by the meter and in many diff sizes. They also supply the crimpings ect. 011 818 2058
Good Luck
RED
Lower, Lower ...........
kloot piloot
Postby kloot piloot » Fri Aug 07, 2009 4:10 pm
You can also try "the Cable Man" in Michael Brinks street (between 13th and 12th Ave) in Gezina. Lots of gadgets there.
Roel Jansen
ZU-IAR powered by BMW 1200
Postby Morph » Fri Aug 07, 2009 8:47 pm
Hyflo are the Fuel attachement guys.
Ask Boet about finger strainers. Made our own for the Bush Babies.
justin.schoeman
Postby justin.schoeman » Fri Aug 07, 2009 10:07 pm
Thanks guys!
On holiday now, but going to hit the ground running on Thursday. Time to fly!!!
Justin
Postby Boet » Mon Aug 10, 2009 10:41 am
Strainers I make out of loudspeaker grille. Cut square, roll around a screwdriver shaft of the right dimension, and solder to brass fitting. Voila! Now it has 100`s of small holes to plug with dirt before the fan stops turning. Cables for throttle, chockes etc, larney bicycle shop. :wink: ( Aircraft grade bicycle cables. Brass spoke nipples make very strong cable ends. Cut off end, and solder to cable. And NO, do not use SS cables. They will not solder!! :evil: )
The right way.JPG (25.23 KiB) Viewed 1130 times
