Knock Detector
doreen
Knock Detector
Postby doreen » Tue Jul 28, 2009 8:15 pm
I am going to test this on BMW R1200 fitted to my Zodiac CH650.
Very simple, anyone can built it for +- R20.00. Tapping with the metal part of screwdriver on the sensor will lit the LED.
knock freq. = 900/ (3.14 X piston diameter(in meters)) Works out to +-2.8Khz for the R1200.
IMG.pdf
(67.32 KiB) Downloaded 264 times
ystervark7
Re: Knock Detector
Postby ystervark7 » Wed Jul 29, 2009 6:56 am
Looks interesting. Please keep us posted on your progress.
I would like to use this as well if it works.
Griffin
Re: Knock Detector
Postby Griffin » Thu Aug 06, 2009 5:59 pm
Is that sensor part of the R1200 motor or are you fitting your own piezo mic to the motor?
What is the frequency you quote? (2.8kHz) Is that the frequency of the pre-ignition "knocking" sound you are trying to detect?
doreen
Re: Knock Detector
Postby doreen » Fri Aug 07, 2009 1:19 pm
Sorry for the late reply. Yes, the R1200 has two knock sensors. And yes, with the info I gathered so far that is the audio freq. when knocking occurs.
