Prop pitching
Massimo
Prop pitching
Postby Massimo » Tue Jul 07, 2009 9:19 am
Ok someone please clarify this for me:
I was under the impression that a coarse prop will give you more climb but less speed and a finer pitched prop will give you more speed but less climb, or is it the other way around? If i want to increase my revs that will mean making the prop less coarse therefore reducing the climb but increasing the cruise, correct?
kloot piloot
Re: Prop pitching
Postby kloot piloot » Tue Jul 07, 2009 9:41 am
Quite correct. vhpy
Roel Jansen
ZU-IAR powered by BMW 1200
Sukkelaar
Re: Prop pitching
Postby Sukkelaar » Tue Jul 07, 2009 9:54 am
I ussually think of a nut on a screw thread. On a coarse thread a nut will move advance 3mm if turned one revolution,and 1mm on a fine threaded screw.
Therefor a coarse prop will be faster.
Sukkelaar
Kyk Noord
Mogas
Re: Prop pitching
Postby Mogas » Tue Jul 07, 2009 10:28 am
Sukkelaar has it right.
Fine pitch = higher RPM and better climb performance.
Course pitch = lower RPM and better cruise performance.
Think of it as lower gearing for hills and higher gearing for speed.
Nottaquitta
kloot piloot
Re: Prop pitching
Postby kloot piloot » Tue Jul 07, 2009 1:34 pm
Oops ! :oops: I read like my @rse !
What I meant was
is correct.
Thanks Mogas and Sukkelaar for the correct info.
Roel Jansen
Re: Prop pitching
Postby Duck Rogers » Tue Jul 07, 2009 2:42 pm
Nice analogy Sukkelaar vhpy
