hang block lubrication?
extra300s
Postby extra300s » Mon Jun 15, 2009 8:35 am
Hi guys. Is any kind of lubrication required on ones hang block (between keel tube and nylon block)? Wing felt just a bit stiffer than normal when doing preflight. Pitch movement is fine, only roll that seems different.
Take to the sky
ZU-CBI
Aerotrike Scout
Triker
Re: hang block lubrication?
Postby Triker » Mon Jun 15, 2009 10:42 am
I had same problem with Aquilla1 wing sqeeking when rolling. The pitching was alright only little sqeeking. This sound was very irritating to me. Somebody said that putting in lubrication causes dirt and dust particles to pack up inside causing other shit.
Dont know if Solo WIngs or Comet Aviation can supply alternate solution to problem.
extra300s
Postby extra300s » Mon Jun 15, 2009 10:50 am
Makes sense. Thanks Triker!
Take to the sky
ZU-CBI
Aerotrike Scout
Tracer
Postby Tracer » Mon Jun 15, 2009 11:16 am
Hi Extra300s,
If you find a solution, please let us know. I have the same problem on my Aquila 2 wing.
RudiGreyling
Postby RudiGreyling » Mon Jun 15, 2009 11:36 am
Tracer wrote:Hi Extra300s,
Ditto!
http://www.RudiGreyling.com
Arnulf
Postby Arnulf » Mon Jun 15, 2009 8:53 pm
demon wrote:I usually use a squirt of teflon spray...works wonders.
Where do you buy teflon spray, and what is the trade name?
Fully agree with the previous posters, a lubricant that attracts dust is not ideal.
Arnulf
Dunesand
Postby Dunesand » Tue Jun 16, 2009 10:08 am
Hi Guys,
There are a few options. Firstly, you can you use a wax spray used to lubricate motorbike chains. We found that the one distributed by Castrol is the least sticky. Problem is still that dust tends to stick to this and by doing so produces grinding paste but as said, the Castrol one is the least sticky it seems. Terribly expensive - more than R100.00 a spraycan I think.
Secondly, I have heard that some Teflon sprays also work - haven't tried it yet and I don't know how dry it gets to once again not attrack dust.
Thirdly, the best option in my view is GRAPHITE POWDER. You can virtually use this everywhere although it is commonly used in the locksmithing industry. I think you get small little bottles called "Just a Puff" by Viro or so. The only drawback here is when applied to much, it shows dirty but it is easy to clean as well.
Hope this helps.
PS: I think you get a teflon spray by WYNN'S.
Cloud Warrior
Postby Cloud Warrior » Wed Jun 17, 2009 6:51 am
Dry graphite lube is the way to go.
Solowings Aquilla
32-4817
Bushpig
Postby Bushpig » Thu Jul 09, 2009 5:55 pm
I used dry graphite powder on my trike hangblock last weekend!!! Worked like a bomb!!!! Bloody dirty stuff though!! Bought 1kg for R45 from my hardware store!! Will never finish it!!!
AQUILLA ZU-DOJ
ZU BBV
Postby ZU BBV » Tue Jul 14, 2009 5:36 pm
My Instructor told me to use clean water?? I did (on his trike) went quiet and never made a noice again.
