Propeller comparison
Kingfisher
Postby Kingfisher » Wed May 20, 2009 3:51 pm
Can anyone give me input on the following ;
Windlass trike with cutback windlass wing , 503 DCDI , E Box 3.47 Ratio.
Currently has a 72" x 30" Pitch Ivoprop (Older type)
Which would be a better prop with this combination & why.
72" x 46" P-Prop or NC 3-Blade. I prefer to support the local guys.
Kiev prop is nice but a bit pricey for me.
Re: Propeller comparison
Postby Morph » Wed May 20, 2009 4:20 pm
What do you want, smoothness or performance
Smoothness go for the 3-blade, performance the P-prop
If it's looks you want, wood is always prettier
convenience wise, a 3-blade is ground adjustable and you can set it up to your exact requirements.
Ranger
Postby Ranger » Wed May 20, 2009 4:37 pm
I agree with Morph. Had a 3 blade warp then changed to P-prop on 503 Aquilla. The P-prop was ever so slightly rougher but it was asif it bit into the air nicely. Looked and sounded nice as well.
Postby Boet » Mon May 25, 2009 8:04 pm
Yip. And then you can allways trust a tree...... :wink:
Users browsing this forum: No registered users and 35 guests
