NEW TRAFFIC LAWS
Please be aware – soon the new traffic laws (AARTO) will be implemented in all provinces.
12 points will be suspension of your licence.
Registration and licensing of motor vehicles:
Violation : Fine : Pts
Motor vehicle not registered R 1 000 3
Motor vehicle not licensed R 1 000 3
Operating vehicle with special licence on public road R 500 1
Motor vehicle with number plates not SABS approved R 500 1
Motor vehicle displaying no number plates Court 6
Motor vehicle displaying only one number plate R 500 2
Motor vehicle with plates not applicable Court 6
Motor vehicle with number plate obscured or illegible R 250 0
Motor vehicle with both plates obscured or illegible Court 6
Licence disc not displayed R 500 1
Licence disc obscured or illegible R 500 1
Licence disc on trailer exposed to weather R 500 1
Operator did not change address particulars R 500 1
Operator did not change particulars of proxy R 500 2
Disposing of unregistered or unlicensed vehicle or of a vehicle with no registration or licensing papers R 1 000 3
Owner did not report motor vehicle stolen R 500 1
Owner did not report motor vehicle permanently unfit for use R 500 1
Motor vehicle does not have an engine number Court 6
Used motor trade plate for other purposes than described R 500 1
Motor trade plate not displayed or displayed incorrectly R 500 1
Transport persons on goods on vehicle with special permit R 500 1
Temporary or special permit not displayed correctly or illegible R 500 1
Display temporary or special permit not applicable to motor vehicle Court 6
Fitness of drivers
Violation Fine Pts
Driver not licensed R 1 250 4
Driver does not have licence with him in vehicle R 500 1
Driver did not disclose disqualification when applying for learner’s licence R 1 250 4
Driver fails to submit licence to licensing authorities of the onset of any disqualifying disability R 1 000 3
Driver did not notify authority of change of address R 500 1
Employ or permit unlicensed driver to drive vehicle R 1 250 4
Driver does not have professional driving permit R 1 250 4
Failed to produce PrDP to court R 1 000 3
Failed to produce licence to court R 500 1
Fitness of vehicles
Violation Fine Pts
Not displaying roadworthy certificate R 500 1
Operating motor vehicle without roadworthy certificate R 1 000 3
Operating vehicle on public road, contrary to notice to discontinue R 750 2
No emergency/parking brake on non-RWC vehicle R 750 2
No emergency/parking brake on RWC vehicle R 750 2
Parking brake inadequate on non-RWC vehicle R 500 1
Parking brake inadequate on RWC vehicle R 500 1
Brakes not in good working order on non-RWC vehicle R 500 1
Brakes not in good working order on RWC vehicle R 750 2
No airbrake warning device R 750 2
Steering gear unsafe or too much free play R 750 2
Illegal left-hand drive vehicle R 500 1
Horn not working properly R 250 0
Illegal window or windscreen R 250 0
No windscreen wiper R 250 0
Defective/no rearview mirror R 500 1
Defective fuel tank, pipes R 500 1
Defective/no fuel tank cap R 500 1
Electrical wiring not properly installed / maintained / insulated etc R 500 1
Engine not covered R 250 0
Inefficient/no silencer R 250 0
Excessive exhaust smoke R 250 0
Fumes in cab R 250 0
Oil dripping onto exhaust R 250 0
Illegal entrances and exits R 250 0
No reverse gear R 250 0
Worn, damaged or illegal tyres (per tyre) R 250 0
Missing seat belt R 500 1
Defective seat belt R 250 0
No speedometer R 500 1
Defective speedometer R 250 0
Defective/no wheel flaps R 250 0
No rear underrun bumper R 500 1
Defective/incorrectly fitted rear underrun bumper R 500 1
Illegal axle on semi-trailer R 500 1
Lighting and reflectors
Violation
Fine Pts
Driving between sunset and sunrise without lights R 750 2
Not using dipped beam with oncoming traffic R 500 1
One rear or stop lamp not working on non-RWC vehicle R 250 0
One rear or stop lamp not working on RWC vehicle R 500 1
Two rear or stop lamps not working on non-RWC vehicle R 500 1
Two rear or stop lamps not working on RWC vehicle R 750 2
Lamps showing incorrect colour on non-RWC vehicle R 500 1
No chevron or incorrectly fitted R 500 1
Chevron not SABS approved type R 500 1
One direction indicator not working on non-RWC vehicle R 100 0
One direction indicator not working on RWC vehicle R 250 0
Both direction indicators not working on non-RWC vehicle R 250 0
Both direction indicators not working on RWC vehicle R 500 1
Vehicle and load dimensions and projection
Violation
Fine Pts
Too long R 500 1
Drawing more than two trailers R 500 1
Too wide R 500 1
Too high R 500 1
Turning radius too great R 500 1
Rear/front overhang too great R 500 1
Load projects too far at front/rear/side R 250 0
Load projection improperly marked R 250 0
Taxis and buses
Violation Fine Pts
Overloading permissible number of passengers by:
1 to 5 R 500 1
6 to 10 R 1 000 3
11 or more R 1 500 5
Bus overloading permissible of passengers by:
1 to 10 R 500 1
10 to 15 R 1 000 3
16 or more R 1 500 5
Not complying with regulations concerning the operation of vehicles carrying paying passengers R 1 000 3
Loads on goods vehicles
Violation Fine Pts
Exceeding the permissible maximum massloads per axle, axle unit, axle group, vehicle or combination by:
Up to 3,99% R 250 0
Between 4% and 5,99% R 500 1
Between 6% and 7,99% R 750 2
Between 8% and 9,99% R 1 000 3
Between 10% and 11,99% R 1 250 4
Between 12% and 13,99% R 1 500 5
Above 13,99% Court 6
Total vehicle mass exceeds 5 times the mass on drive axle by:
Up to 3,99% R 250 0
Mass on the steering axle of articulated vehicle is:
Between 8% and 10,9% of total mass R 500 1
Between 4% and 7,9% of the total mass R 1 000 3
Less than 4% of total mass Court 6
Mass on the steering axle of rigid vehicle is:
Between 14% and 19,9% of total mass R 500 1
Between 7% and 13,9% of the total mass R 1 000 3
Less than 7% of total mass Court 6
Load on one side of axle exceeds that on the other by:
Above 10% up to 20% R 500 1
Above 20% up to 30% R 1 000 3
Above 30% Court 6
Incorrect/no (load data) information plate R 500 2
Insecure load R 1 000 3
Load coming into contact with road surface R 1 000 3
Passengers carried in the goods compartment not safely enclosed R 1 000 3
Operator fitness
Violation Fine Pts
Operator not registered Court 6
Operator card not on windscreen R 500 1
Operator did not notify authority of change in particulars R 500 1
Operator did not report loss of card R 500 1
Operator did not exercise proper control driver R 1 250 4
Operator did not ensure that motor vehicle complies with fitness requirements R 1 250 4
Operator did not conduct operations with due care and safety R 1 250 4
Operator did not comply with dangerous goods requirements R 1 250 4
Operator did not comply with loading requirements R 1 250 4
Dangerous goods
Violation Fine Pts
No fire extinguisher R 1 250 4
Incorrect or missing placarding R 1 250 4
Did not remove placards on emptied packaged goods vehicle R 1 250 4
Placards damaged or not clean or clearly visible R 1 250 4
No danger warning diamond at front R 1 250 4
Left vehicle unattended in an unsupervised area R 1 250 4
Incorrect or missing transport emergency card/s or dangerous goods declaration/s R 1 250 4
No designated space for documents R 1 250 4
Did not ensure that load is compatible R 1 250 4
Transport emergency card older than 3 years R 1 250 4
Road traffic signs
Violation Fine Pts
Disobeying stop sign or robot with non-RWC vehicle R 500 1
Disobeying stop sign or robot with RWC vehicle R 750 2
Overtaking on a white line with non-RWC vehicle R 500 1
Overtaking on a white line with RWC vehicle R 750 1
Pedestrian or cyclist disobeyed regulatory sign R 100 0
Speeding
Violation Fine Pts
Exceeding the speed limit by:
11 km/h to 15 km/h R 250 0
16 km/h to 20 km/h R 500 1
21 km/h to 25 km/h R 750 2
26 km/h to 30 km/h R 1 000 3
31 km/h to 35 km/h R 1 250 4
36 km/h to 40 km/h R 1 500 5
Above 40 km/h Court 6
Lane discipline
Violation Fine Pts
Failing to keep to the left R 1 000 3
Driving on the wrong side or across a dividing strip or traffic island R 1 000 3
Overtaking illegally on the left R 1 000 3
Cutting in after overtaking R 1 000 3
Overtaking on the shoulders or verge R 1 000 3
Overtaking on a blind rise, a curve, or where view is restricted R 1 000 3
Accelerating while being overtaken R 1 000 3
Encroaching the right half of the road obstructing oncoming traffic R 1 000 3
Passing a stationary bus without due care R 500 1
Driving on shoulder when circumstances do not permit R 500 1
Driving across a road when it is unsafe to do so R 1 000 3
Entering a road when it is unsafe to do so R 1 000 3
Obstructing other traffic while changing lanes R 1 000 3
Failing to use indicators R 500 1
Failing to indicate when changing lanes R 500 1
Failing to yield to the right at a traffic island R 750 2
Failing to keep left while making a left turn R 750 2
Turning right while unsafe R 750 2
Failing to keep left while making a right turn (cutting corner) R 750 2
Stopping and parking
Violation Fine Pts
Stopping or parking
Alongside/opposite another vehicle where road is less than 9 metres R 1 000 3
Alongside or opposite an excavation or obstruction R 1 000 3
At or within 6 metres of a bridge or tunnel R 1 000 3
At or within 6 metres of narrow portion of road R 1 000 3
Constituting a danger or obstruction R 1 000 3
Within the railway reserve of level crossing R 1 000 3
On the wrong side of the road R 1 000 3
In contravention of a “no-stopping” sign R 750 2
On a freeway illegally R 500 1
Parking:
In contravention of any road sign R 250 0
Double parked R 250 0
At excavation or obstruction R 250 0
Within the railway reserve of level crossing R 250 0
Within 9 metres of an approach to pedestrian crossing R 250 0
Where width of road was constricted R 250 0
Within tunnel or on a bridge R 250 0
Obstructing a fire hydrant R 250 0
Obstructing a traffic sign R 250 0
On the sidewalk R 250 0
On non-urban road within a metre of the edge R 250 0
Blocking entrance to public road R 250 0
Within 5 metres of an urban intersection R 250 0
On the actuating mechanism of a robot R 250 0
Further than 450 mm from the kerb R 250 0
On road less than 5,5 metres wide R 250 0
On a traffic island or pedestrian mall R 250 0
Towing
Violation Fine Pts
Towrope or towbar exceeds 3,5 metres R 500 1
Towed vehicle not securely attached or not under control R 500 1
No licensed person at the wheel of towed vehicle R 500 1
Towing at over 30 km/h (unless a tow bar is used) R 500 1
Conveying passengers illegally (over 30 km/h) in towed vehicle R 500 1
Accidents
Violation Fine Pts
Failing to stop at an accident to ascertain injuries and assist Court 6
Failing to stop where there is third party damage R 1 000 3
Failing to report accident R 1 000 3
Removing vehicle from accident involving injury or death without police authorization R 750 2
Removing vehicle without the owner/driver’s permission R 1 250 4
Reckless driving and driving under the influence
Violation Fine Pts
Reckless driving Court 6
Inconsiderate driving R 250 0
Driving under the influence Court 6
Blood alcohol level for:
Ordinary motorist not less than 0,05 g per 100 ml Court 6
PrDP driver not less than 0,02 g per 100 ml Court 6
Breath alcohol level for:
Ordinary motorist not less than 0,24 mg per 1 000 ml Court 6
PrDP driver not less than 0,10 mg per 1 000 ml Court 6
Smoked before blood/breath specimen was taken R 1 250 4
Refusing to give blood or breath sample R 1 500 5
Miscellaneous
Violation Fine Pts
Failing to comply with traffic officer’s instructions R 500 1
Unauthorised tampering with vehicle Court 6
Furnishing false information Court 6
False number plate Court 6
Not wearing seatbelt R 250 0
No warning triangle R 500 1
Warning triangle not as prescribed R 250 0
Warning triangle not displayed or displayed incorrectly R 250 0
Reversing too far or dangerously R 1 000 3
Following too closely R 1 000 3
Permitting a person to occupy a position in a vehicle restricting the driver’s full control R 1 000 3
Permitting a person to interfere with the steering or operating mechanism R 1 000 3
Driver not positioned to exercise complete control of vehicle R 1 000 3
Leaving vehicle unattended and unbraked R 250 0
Pulling away from kerb before it is safe R 500 1
Failing to give way to emergency vehicle sounding an alarm (eg ambulance or fire engine) R 500 1
Part of driver’s body (elbow) protruding from moving vehicle R 250 0
Allowing person on roof or step while in motion R 250 0
Engine emitting smoke R 250 0
Leaving engine running unattended R 250 0
Spillage of oil petrol or rubbish R 250 0
Running engine while filling up R 250 0
Jumping on or off moving vehicle, endangering others R 100 0
Driving on the sidewalk R 500 1
Driving while using hand-held cell-phone R 500 1
Excessive noise R 250 0
Hooter used illegally R 250 0
Failing to yield to pedestrian at crossing R 500 1
Pedestrian moving into path of vehicle suddenly at crossing R 100 0
Overtaking stationary vehicle at pedestrian crossing R 500 1
Racing on public road R 1 000 3
Driving in convoy during weekend R 500 1
Wilful obstruction of traffic flow R 750 2
Abandoned vehicle R 500 1
Damaging public road R 1 000 3
Using chocks between wheel and road R 1 000 3
Trading illegally on public road R 250 0
Lets rather fly
- Bennie Vorster
Lets rather fly
Last edited by Bennie Vorster on Thu Apr 23, 2009 9:44 pm, edited 1 time in total.
Bennie Vorster
083 277 5110
Bennie Vorster
083 277 5110
- Stephan van Tonder
Re: Lets rather fly
Seen it before and It's al load of crap. Ill concieved and obviously not read through or thought through. There are a couple of stonkers in there. Driver not licensed - 4 points - The oke doesn't have a license - what are you going to deduct it off?.
Then it's cheaper on points to operate an unroadworthy vehicle and break the law than it is to do it in a roadworthy vehicle. What a joke.. BTW who is going to enforce this debacle - they not even doing the basics at the moment. Again - 1st world system for law abiding citizens trying to be implemented in a third world country full of criminals..
- V
- Whats the right frequency?
Re: Lets rather fly
Two weeks ago I got an instant warrant for this reason for my car on the N1 at a roadblock:Bennie Vorster wrote:NEW TRAFFIC LAWS
The officer surely didn't know about the new rules, because I can now choose between going to court or paying R500 if I admit to being guilty ... Flying is better, no roadblocks ...
Re: Lets rather fly
...........of betaal R250 "BRIBE", en alles is reg
ZU-ALW
Hanger 5-7
Microland
120.35
Hanger 5-7
Microland
120.35
Users browsing this forum: No registered users and 34 guests
