Service update Rotrax
Amenio
Postby Amenio » Fri Mar 20, 2009 5:19 pm
ROTAX RELEASES REVISED SERVICE INSTRUCTIONS
MARCH 19th 2009
Dear ROAN subscriber, Rotax has released Revised Service Instructions listed below.
Within these Service Documents, changes and additions introduced with these
revisions are indicated by double vertical bars on the left hand page margins.
SI-912-003 R2 / SI-914-005 R2
Oil Connections with UNF Threads (AN-8) for
Rotax Engine Type 912 and 914 (Series)
A new UNF thread (AN-8) fitting with an 8 degree slope is now available.
This fitting is designed to be placed at the bottom of the crank case for oil return line connection to the oil tank.
This fitting allows more clearance and routing options for the connection of standard Aeroquip or Stratoflex oil lines.
The fitting can be ordered as a spare part, or as an optional configuration on a new engine.
Fly were no roads lead.........
