Selling composite propellers
Re: Selling composite propellers
Owners of short take-off and landing aircraft finally chose 2-blade propellers with a diameter of 79". There are so many orders that you will have to make additional production equipment.
https://www.stolspeed.com/nid/46
I hope that the test results will be interesting for everyone.
Sent a "champion propeller" for engines up to 300 hp.
A 2-blade propeller with a diameter of 78.7" is available for bush pilots.
Price please.
Jean
Dear Jean, I'm sorry I didn't see your question. I sent a private message.
106-1770 is ideal for Rotax-912-100 (C-42B).
- 106-1750-С-42-Pertti-.jpg (32.14 KiB) Viewed 50345 times
meglin wrote: ↑Sun Jun 05, 2022 12:11 pmDear Jean, I'm sorry I didn't see your question. I sent a private message.
[/quote
Hi Vladimir, I did not get your PM. Please email me, aerokits99@gmail.com
Jean
Compose.
For sale a new 2-blade left-hand propeller with a diameter of 67". Perfect for pulling Rotax-582/2,58.
for today I have in stock:
1) 2-blade propeller with a diameter of 2000 mm (78,7"), pulling right, saber-shaped, hub 101.6 mm - for pulling Rotax-912-914,
2) 2-blade pulling left with a diameter of 1700 mm (66.9"), straight blades, hub 75 mm - for pulling rotax-582/2,58,
3) 3-blade 1750 mm (68.9"), pulling right with hub 75 mm, truncated saber - for Rotax-912,
4) 3-blade pushing left 1750 mm (68.9"), truncated saber - for pushing Rotax-912,
5) wooden 1400 mm (55,1") left pulling on Sauer S2100,
6) wooden 72*44 right rotation for Continental 100 hp.
7) 3-blade propeller for a motor with a power of up to 150 hp, saber-shaped blades of right rotation, pulling, there are traces of installation on the hub
Just in case, I will inform you about the available propellers.
1) 2-blade propeller with a diameter of 2000 mm (78.7"), rotary, salt-forming, hub 101.6 mm - for Rotax-912-914 thrust,
2) 2-blade leveler on the left with a diameter of 1750 mm (68.9 inches), straight blades, hub 75 mm - for sinking rotax-582/3-3.47,
3) 3-bladed 1750 mm (68.9"), stretching to the right with a 75 mm hub, a truncated saber - for Rotax-912 - is already gone,
4) 3-blade pusher left 1750 mm (68.9"), truncated saber - for pushing Rotax-912, - already gone,
5) Wooden 1400mm (55.1") left rod for Sauer S2100,
6) wooden right rotation 72*44 for a 100 hp Continental.
7) 3-blade propeller for an engine with a capacity of up to 150 hp, saber-shaped blades of right rotation, pulling, there are traces of installation on the hub
right thrust for R-912-100 with a diameter of 1805 mm, truncated saber
Vladimir , how much for this propeller , shipped to me in South Africa ?
Jean
