GOOD QUALITY HELMET CAMS
- Reuben zu-ccm
- Learning to fly
Re: GOOD QUALITY HELMET CAMS
TC
Very good quality photos but the sound quality on my Drift HD 170 is not there do you guys have the same problem ????? do i have to buy a external mic to
improve the quality ???
Reuben ZU-CCM
Reuben ZU-CCM
- Tribal Croc
Thanks Reuben
At this stage I set my mic setting at the minimum so that I don’t get the engines noise the whole time.
I am thinking of getting the external mic and modifying it to go into my buzzcom and use this setup for longer trips to get some radio chatter into the movie
- Reuben zu-ccm
- Learning to fly
Hi TC
No my volume is set to max with no sound at all will have to take it back to Action Cameras to be checked out .
have not been flying to much this couple of weeks as the weather was bad hope to do some flying during the Easter weekend if you want to fly to Kroon one morning i will meet you there just let me Know ,in the air or on the ground .
Thanks Reuben 0829094722
ZU-CCM
ZU-CCM
- Tribal Croc
Thanks for the invite
My trip is as follows
Fly from here (Ntokozo) to
Crater via the swamps then to
Kroon for leg stretch then to
Aviators Paradise for a touch and go then
Aeroden for coffee and refuel then
Rooikoppieddam then
Vaalkopdam then
Follow the Crocodile River up to Koedoeskop and
Finally head back home
All and all it’s about 133nm
And naturally I will be playing around with my Drift HD170
- Reuben zu-ccm
- Learning to fly
TC
The trip looks good !!!
Hugo and i might pop in for some brekkie during the weekend if weather turns ????
Reuben ZU-ccm 0829094722
- Tribal Croc
Video I made this morning called "Dam hopping"
http://www.youtube.com/watch?v=ReukFt37 ... er&list=UL
Ah now that really looked good.
Hmmmm maybe need to look at getting one of those for the Pink Lady ?
- CHARLIE WHISKEY
- Whats the right frequency?
Hi TribalC
Looks like you tested your HD170 well.
Do you use the 760dp or the 1080p setting?
Fueled by Faith.
ZS-VMP
ZU-BBR
ZU-CMS
ZS-WFT
ZU-FGR
ZU-CTS
ZS-VMP
ZU-BBR
ZU-CMS
ZS-WFT
ZU-FGR
ZU-CTS
- Tribal Croc
Hi CWCHARLIE WHISKEY wrote:Hi TribalC
I have only used the 1080p setting but see that your fish eye angle is a bit bigger if you use the 720p setting.
Will still play around and see if there is a big difference between the 2
Anyone mounted a cam on a Raptor wing yet? The washout tube is inside the wing, so not as easy as the Aquilla.
- Mc Guyver
- Solo cross country
The Drift captures in .MOV What is the best way to burn it onto a DVD to play on a DVD player ?
- Mc Guyver
Thanks for the fast response.Alkemac wrote:Simply rename it as .AVI...
I tried doing that but when trying to add the file it comes up with MOV not supported (after renaming)
What could I be doing wrong?
