Selling composite propellers
meglin
Re: Selling composite propellers
Postby meglin » Sun Jun 02, 2019 5:14 pm
Vega 2000 jabiru 2200 SR-45-1620-2... 'Propeller climb
blade angle 21.7 degrees, engine 2980 rpm Max at the fixed point.
airspeed 200 km / h at 3000 rpm and 180 km / h at 2800 rpm.
perfect takeoff for about 150 m; and climb to 100 ft/min."
Best regards
Vladimir Meglinsky
My site: http://propeller.mozello.com/
meglin
Postby meglin » Mon Jul 15, 2019 9:07 am
Friends, colleagues! I will try to neutralize the impact of holidays on the execution of orders. Work won't stop!
Best regards
Vladimir Meglinsky
meglin
Postby meglin » Wed Jan 01, 2020 1:47 pm
Happy New year, colleagues!
Best regards
Vladimir Meglinsky
meglin
Postby meglin » Sun Jan 12, 2020 2:06 pm
Another savage with our propellers.
Best regards
Vladimir Meglinsky
meglin
Postby meglin » Tue Mar 03, 2020 6:01 pm
The black-and-white photo shows a propeller with a diameter of 2000 mm.
Best regards
Vladimir Meglinsky
meglin
Postby meglin » Sun Jun 07, 2020 3:43 pm
Friends from France are testing our propeller on the Jabiru-2200 engine
Best regards
Vladimir Meglinsky
meglin
Postby meglin » Tue Jun 23, 2020 11:31 am
I hope that the harsh African winter did not prevent the use of aviation equipment?
Best regards
Vladimir Meglinsky
meglin
Postby meglin » Sun Jan 17, 2021 12:27 pm
We decided to expand the production of wooden propellers and reduce the waiting time for an individual order to 2-3 weeks.
Best regards
Vladimir Meglinsky
Postby Jean Crous » Fri Jan 22, 2021 7:14 pm
Vladimir, tell me honestly, how does your wooden 2 blade prop compare to the 3 blade ground adjust for take off and cruise performance on a R0tax 912 ULS. Lets say it is in a Rans S7 type aircraft, similar to the Savage Classic ?
Jean.
meglin
Postby meglin » Sat Feb 13, 2021 1:35 pm
Hello, Jean! Compared to which 3-blade propeller? Our three-bladed saber-shaped engine outperforms most other propellers in terms of performance and low noise. But recently it was discovered that the flight characteristics of the 2-blade versions are superior to the 3-blade ones in almost all flight modes. But they are somewhat inferior in noise. Therefore, German pilots continue to purchase 3-blade versions from us, and South African pilots prefer two-blade ones. The most prudent buy 3-blade propellers and buy additional 2-blade hubs. In this case, they use two versions of the propeller. As for the wooden propeller, there is a continuous struggle for perfection.We do not make mass-produced wooden propellers. Each propeller is made by special order. And each propeller is more perfect than the previous one. New profiles are used, the twist, narrowing, angles, and shapes are changed. It is possible to change the geometry after each released propeller. There is a continuous accumulation of experience. The only drawback is that it is impossible to take into account the real state of a particular motor, it is impossible to flexibly adjust to it. That is, you can design and build the perfect propeller for the perfect Rotax-912 today. But during the adjustment, your motor may wear out, and its characteristics will change. And yet-the propeller will no longer be ideal for him. the queue for wooden propellers is much longer than the queue for plastic propellers. Now we have opened a separate production of decorative wooden propellers.
S-7 R912-80-1700---.jpg (83.98 KiB) Viewed 24783 times
Best regards
Vladimir Meglinsky
Postby Jean Crous » Sun Feb 14, 2021 4:56 pm
Thanks Vladimir, appreciated !
Jean
meglin
Postby meglin » Fri Feb 26, 2021 12:34 pm
Friends, my son leads a group of programmers from different countries. They can handle many tasks. If there is a need - contact us!
Best regards
Vladimir Meglinsky
meglin
Postby meglin » Thu Mar 04, 2021 6:47 pm
I am now sending to France these blades for a home windmill. The diameter is about 2 m (79"). Very light - about 700 g (1.54 lb). Easy to install on a flat flange. Maybe someone else needs it?
Best regards
Vladimir Meglinsky
meglin
Postby meglin » Sat Mar 13, 2021 5:38 pm
The next plane with our propeller
Best regards
Vladimir Meglinsky
meglin
Postby meglin » Sun Mar 14, 2021 10:08 am
The production of the windmill blades shown above was destroyed during the occupation.
Best regards
Vladimir Meglinsky
