Tips on flying in turbulance
Postby Tailspin » Fri Aug 19, 2005 9:09 am
WOW :shock: Can PIO get really that bad that you can go inverted :?: :?: Suppose you gotta be flying in some really BAD turbulance.
:shock: :shock: :shock:
Fairy Flycatcher
Postby Fairy Flycatcher » Fri Aug 19, 2005 11:39 am
Tailspin wrote:WOW :shock: Can PIO get really that bad that you can go inverted :?: :?: Suppose you gotta be flying in some really BAD turbulance.
This is a serious, but all too common, misconception. It is PILOT induced oscillations. Not WEATHER induced.
PIO are actually quite common in perfectly smooth conditions.
Example. You were told to fly finals with the bar into your guts. You turn finals, but not quite lined up on the runway. You turn slightly, to line up. Because you are too fast, your turn extends past the intended angle, you then try to turn it back.
Because the aircraft has already begun the turn back to level, and you are too fast for what you are used to, your input actually increases the turn into the opposite direction (over-correcting, easier when flying fast, and depending on the roll stability of the trike!)
You then try to correct the turn in the opposite direction, again too late or two slow or two long, and your oscillations become increasingly severe. A very frightning place to be!
Solution: Ease of the bar, go with the turn, and get it under control. On finals, do go-around. It is though, something which can feel a lot like turbulence, and this is where it is imporant to see what your airspeed is, too fast, chances are its PIO.
Annie
www.comefly.co.za
Re: Tips on flying in turbulance
Postby Madman » Tue Jun 28, 2011 8:50 am
Major Bump...
Thought this would be an interesting read for new and experienced pilots...
I love reading the old topics..really learn alot.. ##
Thank you for the awesome info :!:
s023
Flooi
Survived first engine out
Postby Flooi » Tue Jun 28, 2011 9:46 am
Remember that turbulence and windy conditions effect low wing loading wing
aircraft more dramatically. Simply stated: the bigger the wing in relation to
the all up weight, the shorter the runway you use BUT the more sensitive you
are to turbulence. A smaller wing will require more runway and less effect
by turbulence.
Also- study the weather. Cold fronts are dangerous! Stay away from flying a
microlight just before, during and after an cold fromt.
This website is very usefull:
http://www.windfinder.com/forecast/Joha ... bo_airport
Users browsing this forum: No registered users and 28 guests
