Hi Frank, great, else see you for take off at 5.
Paul Mulder
Tailwinds are the best
ZU-DBC Aquilla
Pretoria
ZU-DBC Aquilla
Pretoria
Paul Mulder
ZU-DBC Aquilla
Pretoria
ZU-DBC Aquilla
Pretoria
Kannie, wag nie!
Paul Mulder
ZU-DBC Aquilla
Pretoria
ZU-DBC Aquilla
Pretoria
- Louis Cole
- Whats the right frequency?
Hi Guys, the weather looks good according to Windguru so I'll be flying through tomorrow morning sparrow and drive through Thursday afternoon for the flight briefing and park in Alan's hangar for the weekend. Jaco has kindly offered to put me up for the night which will greatly reduce the last minute.com scenario for Friday morning otherwise. Thanks for all the help so far from the ML crowd. Looking fwd. to it .
Loneranger
ZU-CEX Raptor 618
25 52.869' S 027 54.940' E
"Reach for your dreams"
ZU-CEX Raptor 618
Nice one Louis, the weather does look favourable in PTA this morning, good luck and fly safe.
Just ask Fanie or Merv at Skyriders to open the hanger for you. Johannes should also be around to give you a hand. If you sukkel, give me a shout, I'll tell you where the codes are to the locks.
Louis as I'm sure you guys know by now is one of my wingmen for the TRO next year. I'm really glad he is joining us to Elands as it give us the chance to see how our trikes fly together. On such a long overland trip planned next year, we need to get the speeds right. Louis should be a little faster...question is how much?
Last night I plotted our intended route to elands on transparencies, must just jot down the flight notes and frequencies. GPS will be used when you hear "Uhm....this is DBP....where the hell are we guys?"
I nominate Paul to lead our Samoosa Squadron
Morning Guys.
Great that Louis is definitely in
and...Al, the WX is looking better and better
Positive...positive...positive thoughts^
From my calculations using mapsource and vfrplanner, for the direct route,...radio wise...we report on SRA East 125.4Mhz until 25 miles out, crossing R513, then FAD128, Pta FTA 124.4Mhz (Afsaal AF, overfly & report 124.4Mhz). 47miles out change to Country, 124.8Mhz. Elands...80miles out, report on country.
Compass heading including W17.7 deg variance .....direct route 54 deg mag. Via Loskop & Groblersdal..77 deg, 21 deg, 319 deg. Back, direct 232 deg. Via Rust de Winter and JAG, 268 deg, 190 deg, 218 deg ML.
I prefer using my GPS. Even if visibility is low, I can still see my GPS. They are also very very reliable especially the aviation units. They comply to military spec...even for gamma and beta ray penetration which is an issue when you fly at 50 000ft...haven't tried that yet
. Will load all the routes on Thursday.
Paul
Paul
Paul Mulder
ZU-DBC Aquilla
Pretoria
ZU-DBC Aquilla
Pretoria
- Looking at the sky
Starting to look good for this weekend. Just done calcs for route via Loskop and Groblersdal and with 4 knot N wind switching to easterly at Loskop we will have 136min flying time and 34l fuel at 15l per hour. This assumes an airspeed of 43knots (49.5mph, 79.6kmh). So should be no problem even allowing for pee stop at Groblersdal. As you can see I don't have enough to do at work .
Cheers Frank
Cheers Frank
Hi Frank, as you can see, things are winding down here too.F Smallwood wrote: As you can see I don't have enough to do at work.
Given
Direct. Dist = 74 nm, Time = 1 h 47, fuel = 26.7 ltr...half tank left
Cheers Paul.
- image.jpg (79.67 KiB) Viewed 1416 times
Paul Mulder
ZU-DBC Aquilla
Pretoria
ZU-DBC Aquilla
Pretoria
- KlapperKnop
- I hate turbulence
MicroLanders seems I can fly with you possibly for around 40NM and then return back to ML. Flight to CPT is only 10am.
ZU-DJE
- nicow
Jy waag baie...KlapperKnop wrote:MicroLanders seems I can fly with you possibly for around 40NM and then return back to ML. Flight to CPT is only 10am.
Now that's commitment!KlapperKnop wrote:MicroLanders seems I can fly with you possibly for around 40NM and then return back to ML. Flight to CPT is only 10am.
Anthony Hugo
Crosswinds
Crosswinds
Yip, we've trained Mr Salie well....now that's what I call "gees"anthonyhugo wrote: Now that's commitment!
Good on you Fiz, we roll 5AM mate
PS...Louis...dont forget your glasses on Thu...the GPS makes more sense with them on!
- Blue Max
I enjoy reading this thread.!!
Manne julle moet nou nie onnodig skrik vir n paar los wolkies nie.. Dit is baie selde dat n ou n heeltemal skoon lugruim kry.!!
Wanneer n ou eers bo in die lug is vertoon n klompie los wolke anders as wanneer jy hulle van die grond af beskou.!!
Skakel my vroeg oggend , so 5 uur se kant, by die plaas en ek vertel jou hoe die weer daar lyk. As die weer k@k lyk en die wind waai dan gaan ek jou se.
O8255 nege6115
Die hoof runway le op 04 en 22 en is meestal op 04 dat n ou land..
Die crosswind is net geskik vir n trike en le omtrent op 09 en 27..
Die windkouse is al gaar gebrand, so wanneer jy naby die plaas is kyk na rook en ook die water wat die besproeiings boere sproei, dit gee jou n goeie aanduiding van die wind rigting..( en as jy jou aerie ken weet jy wat die wind jou vertel..) Ek sal in die lug wees om jou te help.!!
Lets have a great weekend..
Wow Feiz, why don't you just return and go all the way to CPTKlapperKnop wrote:MicroLanders seems I can fly with you possibly for around 40NM and then return back to ML. Flight to CPT is only 10am.
Ek kan sien hirdie man like van self flieg...Feiz dit is riskant
Thanks Paulus, we will definitely call you before take off.
My sun-readers are packed. Old eyes...Al won't know about such challenges.
Paul Mulder
ZU-DBC Aquilla
Pretoria
ZU-DBC Aquilla
Pretoria
Forgot to tell you guys,
Pieter had to pull out due to work
Looks like just 5 trikes flying up from Faba on Fri.
Thanks for posting the Maghdng's Paul....looking for my protractor this afternoon...my dear son tells me...
"oh yes daddy....I was playing with it and it just broke by itself"
I wonder when he's gonna move out??
