Cloud Warrior
Postby Cloud Warrior » Sat Feb 28, 2009 1:26 am
OG
I see that there is a Porsche 911 in the background with (skande!) some junk on top of it! Also seems to be very dusty?
This is totally unacceptable!!!!!!!!! :wink:
Please remedy the situation as this is an insult to my sensibilities.
Yours faithfully
CW
Solowings Aquilla
32-4817
Postby Boet » Sat Feb 28, 2009 8:21 am
THAT Portsh is a loooooong term restoration project. I tried to buy it from Oupa. He said NEEE. And went on to explaining something interesting about the Bee Em engine..... :roll: :roll: :roll: :roll: :roll:
Oupa-G
Postby Oupa-G » Sat Feb 28, 2009 4:14 pm
Cloud Warrior
I f you have a problem with the Porsche come and visit from OZ and you can fix the Porsche it is all original and I was the first owner. When the Bosvark is finished she will get the same energetic attention. The Bosvark must first fly. At this stage rather ask something about the technical stuff that I've been posting. Later tonight you will see the exhaust in situ for its first fit like a suit from the tailor.
Cheers Oupa-G
Ian
Postby Ian » Sat Feb 28, 2009 5:28 pm
Oupa-G
Your thread is the first I read... thanks for the posts vhpy
Your exhaust quality looks stunning, it has all my attention now, I built a Savannah and the exhaust supplied by the Italians is stainless but they bugger it up with spot welding the baffles in position (or the used the wrong welding technique, I'm no expert). I'm sure you dont intend to do the same. They must have fixed this problem as all the newer Savs dont seem to have an issue (mine was about the first kit in SA).
Pic below is the exhaust after 126 hours.... pathetic.
Holey exhaust ......
sholes in exhaust.jpg (26.32 KiB) Viewed 3079 times
Oupa-G
Postby Oupa-G » Sat Feb 28, 2009 6:54 pm
Ian thanks please show me a bigger picture so that I can orientate myself. An Exhaust is such an important component you can start a fire and you can prevent a fire, we opt for the last option. The whole exhaust is now tacked and will then go to my expert welder. Vliegvark does a mean welding job . Once the Bosvark is flying I will report back and after 100hrs we will know about cracking although we have tried to eliminate oil canning.
Enjoy the pics
Cheers Oupa-G
Header pipe everything fits no tension
Silencer hangs from engine mount nicely balanced
Another view
Oupa-G
Postby Oupa-G » Sat Feb 28, 2009 7:01 pm
The previous pictures gave a view from the inside. We worked all Saturday fitted the outer cladding thanks to CAD design and laser cutting no more filing just perfect fits. The outer cannister is in three pieces this helps with the welding of the inside components. Then the three outer pieces are welded onto the inner structure, and "Voila"
Some more pics
Cheers Oupa-G
Ian
Postby Ian » Sat Feb 28, 2009 8:03 pm
VERY nice Sir :!:
He looks like he is welding the baffles in, not a spot weld so it shouldn't do what mine did. (but then I'm just a part time builder, not dragon flame metal glueing expert...)
If your header pipe works it's gonna save plenty people a lot of time..
Here is a pic which shows my previous pic in perspective
2nd pic is my spring fitter, no scratching of the spring loop, works great...
Pic taken in direction of arrow which is almost same colour as your Porsche....
exhaust hole locator.jpg (68.99 KiB) Viewed 3024 times
Ian
Postby Ian » Sat Feb 28, 2009 8:20 pm
Sorry to post so many pics under your thread.... but just downloaded this one from my cellphone, shows the perspective you were after :?
Cheers ian
holes can be seen in this pic, one other hole in rear
Holes in exhaust still new.jpg (36.04 KiB) Viewed 3011 times
Oupa-G
Postby Oupa-G » Sat Feb 28, 2009 8:29 pm
Thanks Ian
From the discoloration the hot gases go in at the outer section and then flows to the center section and then outwards ala Rotax muffler , our one cyl breaths along the full length then through all the holes anthen into the exhaust pipe the ofset is the same as the ofset of the cylinders. I'll send some more pictures after I have taken them.
Cheers Oupa-G
Oupa-G
Postby Oupa-G » Sat Feb 28, 2009 9:18 pm
All the tacking was done the concept seems to fit running the engine and flying it on Vliegvark which has a standard BMW exhaust will tell we will fly it with the same prop. Weight Bosvark exhaust 4.5kgs complete the standard BMW exhaust 10kgs wE WILL SEE HOW NOISY IT IS.
Cheers Oupa-G
10kgs
5kgs
Oupa-G
Postby Oupa-G » Sat Feb 28, 2009 9:21 pm
The photo session will stop for one week going to Upington via Loeriesfontein will see you again after the 6th of March. Some final pics
Cheers Oupa-G
Side view
just another view
Postby Boet » Tue Mar 03, 2009 4:27 pm
Saf no 2 yellow sprayed on. Blue to follow on Thursday. Camera on the fritz. will post some pics on Thursday. Now off to the fairest, hope to be back tomorrow evening. vhpy
Postby John Boucher » Wed Mar 04, 2009 6:30 pm
Camera on the fritz..... ?
Sounds like a familiar phrase.... vhpy
The work being done Oupa-G looks very good!
Postby Boet » Fri Mar 06, 2009 1:06 pm
Sparayed colours on. Fuselage on wheels for the first time. Made up the panel for my own aerie as well. do I hear oom Priester say something about " n Simpel ou TV`tjie" ??????? :evil: vhpy vhpy vhpy
SAF 2.JPG (59.83 KiB) Viewed 2522 times
Boet s`n.JPG (73.05 KiB) Viewed 2521 times
Oupa-G
Postby Oupa-G » Fri Mar 06, 2009 8:34 pm
On the way to Upington and back I popped in with Boet and we had a lekker chat Safari II is coming on well. Tomorrow it is back on the Bosvark in full swing my D day is still end of April will post some pictures tomorrow. I see the site has topped 19000 hits what a compliment.
Cheers Oupa-G
