How do you plan to attach the bonnet? Looks like a very nice idea and will allow you to thoroughly inspect during preflight and even perform minor maintenance without removing the cowl.
What is that fuselage next to your BB?
Watch these very carefully. Where is the radiator installed? At the back against the firewall? I originally had mine installed there and I had major overheating problems. Could not get it to cool properly, even with ducts and plates and ......Dusty Eagle wrote:I do find that the temperatures are/might be a problem. When the oil temps finally go up into the green, the CHT temps go into the yellow.
I'm told that this is ok and is due to low ground speeds and insufficient flow through the radiator to cool properly.
Any comments??!
