Postby Eagle » Wed May 21, 2008 2:49 pm
Well guys this is by far the most beautiful trike anywhere in the world !
Congratulations Robert i envy you !
Herewith some specifications i received from the French:
iXess TANARG 912
*Wing span: 10 m / 32.81 ft
*Wing area: 15 m² / 161.46 ft²
*Aspect ratio: 6.66
*Nose angle: 120 Deg
*Wing weight: 53 kg / 117 lbs
*Payload: 211 kg / 465 lbs
*Height: 3.45 m / 11.32 ft
*Engine: Rotax 912
*Engine power: 80 HP
*Cooling system: Water
*Reduction ratio: 2.43 : 1
*Propeller: 3-bladed composite Arplast
*Diameter: 1.66 m
*Noise level* : 68 dB
*Best fuel consumption: 10 l at 95 km/h / 2.64 US gal at 59 mph
*Minimum speed: 62 km/h / 39 mph
*Maximum speed: 150 km/h / 93 mph
*Climb rate: 5 m/s / 984 ft/min
Performance figures are given for dual-seaters with a 180 kg loading.
* Measure taken with full power at 150 m (500 ft) from the ground
Prices range from Euro 25 371.00 to Euro 35 119.00
- tanargrear_329.jpg (45.49 KiB) Viewed 719 times
Nic Prinsloo
Managing Member
Eagle Aviation
Where Flying is a Passion......
Branch Contact Info:
Mobile: 076 970 2758
Skype: nicprinsloo
Email:
Eagle@connect.co.za
