ALTERNATIVE AVIATION ENGINE
justin.schoeman
Re: ALTERNATIVE AVIATION ENGINE
Postby justin.schoeman » Fri Jun 13, 2008 7:38 pm
I just got this from RotaMax:
Our twin carb engine can be purchased with or without gearbox:
RotaMax 1300 C 10,995
RotaMax 1300 CG 12,995 (with gearbox)
With accessories, it looks like this:
1300 Carb, w/ radiator & exhaust
RotaMax 1300 Exhaust Kit 750
RotaMax 1300 Radiator 450
12,195
1300 Carb w/gear redrive, w/ radiator & exhaust
14,195
Our engine comes with a 32 amp stator coil, 45 amp optional is available. We offer twin plugs per rotor, twin coils, twin CDIs. We only have one stator coil.
http://www.rotamax.net/avi_pwrcur.html will show you the 1300 power curves.
There is no oil cooler because the engine does not recirculate oil. It is a lost oil system. So you have a fuel reservoir, and an oil reservoir. The oil is injected into the needle roller bearings and moved through the engine to help the seals. It is a "dry" engine, not a wet sump engine. This is better for you in that you never have to monitor or worry about oil temp, oil filters, oil fans or coolers. Just add fuel and then add oil and you are done.
Eric McCall
emccall@rotamax.net
419-694-3000x260
I specifically asked for carbs + CDI (simpler is better!). Seems like incl accessories it is a touch cheaper than an 85hp Jab for 130hp! Estimate R50k for overhaul every 1000 hours, which is more expensive than the Jabi (but cheaper than the Rotax).
This is a REALLY tempting option!
-justin
Postby John Boucher » Sat Jun 14, 2008 2:39 pm
RotaMax 1300 EFI
RPM TQ HP
3500 127 84
3750 130 92
4000 131 101
4250 132 108
4500 132 114
4750 133 121
5000 129 123
5250 128 128
5500 125 132
Man, I Like I Like.....
grostek
Postby grostek » Sat Jul 05, 2008 7:59 pm
Have found this link on the web about engines
Lots of info
http://www.rotaryforum.com/forum/archiv ... /f-31.html
Kind regards,
Gunter Rostek.
