EGT help needed
I hate bird strikes
I hate bird strikes
Re: EGT help needed
Postby Frequent Flyer » Tue May 13, 2008 2:31 pm
vhpy go ahead 3wheels, you know he's my first love / or is it the 2nd / 3rd :?: :?:
Stephan Du Plessis
Freq 118.90
FAGG - RW 11/29
082 921 5396
3wheels
Re: EGT help needed
Postby 3wheels » Tue May 13, 2008 2:44 pm
Frequent Flyer on Tue May 13, 2008 2:31 pm
:lol: :lol: The 1'st , The One and Only :!: :!: :!:
P.S did you come right :?:
ZU-"Charlie"YV
Re: EGT help needed
Postby Duck Rogers » Tue May 13, 2008 4:11 pm
Morph wrote:The phodies are a bit dark but look fine to me. Definately not running lean
Ditto.............no problem there.
(Pm received)
Tjoek
Re: EGT help needed
Postby Tjoek » Fri May 23, 2008 7:50 pm
Stephan, only saw your thread now. When I got the plane, I took the EGT guage out and had it tested at Aviation Engines. They connected their probes, heated them and looked at the reading. Niren concluded that the guage is OK and it must be the probes. He told me that a change in probe lead length could result in wrong reading. Thus my conclusion. After evaluating the vital signs (e.g. plug colours), I left it at that. If the EGT reading of 800 - 900C was correct, the engine would not last an hour. This is one of the reasons I flew it as is and disregarded the EGT's.
Let me know if you determine the cause.
PS: I always used 158 main jets, because it only operated on the Highveld (5'100ft). That should work perfect in Kuruman as well.
I hate bird strikes
I hate bird strikes
Re: EGT help needed
Postby Frequent Flyer » Sat May 24, 2008 9:27 am
thanks tjoek, i decided to leave it as it is as well. I flew her for 30 hrs now and everything looks ok. Last 12 hrs was a trip to hakskeenpan and back the last 3 days(2 guys from aeroden 912s cobra - bennie, a 503 windlass - echard and my hangar mate -also a 503 windlass) . She really fly's like a dream in a bit adverse weather (like we had - 25-35mph headwinds ect bumps galore) . I changed the prop to a nc prop and what a difference that made! The gearbox developed a leak on the propellor shaft during our trip (on the back of the gearbox housing - will need to monitor that - little bit play on the back bearing.)
Stephan Du Plessis
Freq 118.90
FAGG - RW 11/29
082 921 5396
