The video shows the work of our aircraft on settling Trichogramma on corn.
https://www.youtube.com/watch?v=3gC1C9Di1gM
Rotary atomisers for sale
Re: Rotary atomisers for sale
How or what do you use for directional flight when spraying
Specialized GPS
what is the cost of gps , the landones we used on tractors is to slow
We produce our own navigators in Odess
The software and system unit cost 700 euros. They are compatible with your phone or tablet.
We are preparing a spray system for airmen in Cambodia. They asked for a flow rate of up to 10 l / ha. We delivered a new powerful brushless motor with variable performance, a new electric crane with increased cross-sections. The pump constantly mixes the liquid in the system, and when the electrically controlled tap is activated, the liquid is fed to the sprayers. Jet pumps are also used to increase productivity. The flow rate of the liquid is controlled by an electronic flow meter.
Weighed some units
The photo shows an atomizer, an electric crane, and an ejector jet pump.
The protractor for setting the angles of the blades
A new powerful pump that easily provides a solution flow rate of 10 l / ha.
Performance is controlled by the pilot from the cockpit.
But at high consumption, the battery should be fresh, and it is better to have a spare one on charge.
- IMG_20200905_193307---.jpg (40.2 KiB) Viewed 10810 times
The first trike in Cambodia with our equipment processed the first thousand hectares:
https://www.youtube.com/watch?v=OrJUSbETT4o
In Mozambique, two of our X-32 aircraft were working in the fields. No one knows how to contact the owners? Maybe they need help?
