Air nav pro
JvTonder
Re: Air nav pro
Postby JvTonder » Fri Jun 21, 2013 8:46 am
mulderpm wrote:
JvTonder wrote:Hi Mulder Pm thanks for the info, I do go to the mapstore and see the maps but it just does not download, maybe because I use the GSM will try with a wifi connection and see what happens.
You are brave and wealthy. These files are 300 meg. That is why WiFi is required. The download is also very very slow. Takes hours. Hope you are succesfull.
Brave maybe :twisted: but wealthy beslis nie :( Will let you know if I am successful.
Flying feeds the soul!
Z-MRP
Re: Air nav pro
Postby Z-MRP » Fri Jun 21, 2013 10:25 am
Hi Turbo, the major problem with ANP in zimbabwe is we can only download the map of zim,its basiclly a map from google. You can zoom in and even get street names, no much use if you are flying, it has very limited aviation data on it, ie just he major airports are marked,this is the snag.
As for using it, yes it works perfectly I have no issues with that side of it.It would be great if it had the airspace info maps.
This is where Skydemon has the advantage over ANP for use in zimbabwe.
Turbo
Re: Air nav pro
Postby Turbo » Sat Jun 22, 2013 7:37 am
Z-MRP wrote:Hi Turbo, the major problem with ANP in zimbabwe is we can only download the map of zim,its basiclly a map from google. You can zoom in and even get street names, no much use if you are flying, it has very limited aviation data on it, ie just he major airports are marked,this is the snag.
Z-MRP -- I hear you, it doesn't have all the smaller air field data in it, but for South Africa, it has almost all of them, and if you can find one, you can put in the coordinates of it, and set a waypoint to it that way. Never heard of sky demon, will definately check it out too.
Gadget
Re: Air nav pro
Postby Gadget » Sat Jun 22, 2013 7:46 am
Hi Folla.
If you can find an electronic version of the aviation maps for the missing countries you can send them to ANP and they will digitize them for you. I use the android version with tracking and have never looked back. It is easy to use and contains most of the airfields you need. Just waiting for the EFIS ability on android. I use EasyPlan as a backup as they still haven't brought out the android version.
If there is grass between your toes , you're flying to low.....
If ever in doubt about flying - drink a beer.
That will give you at least 8 hours to think about it some more.
ZU-EPH Bushbaby Explorer 912UL (Morph built)
bobthebuilder
Re: Air nav pro
Postby bobthebuilder » Mon Jul 01, 2013 4:26 pm
Is there a way to display JHB Special Rules areas?
Byron Kirkland
Turbo
Re: Air nav pro
Postby Turbo » Mon Jul 01, 2013 10:07 pm
Yes there is I asked this question of ANP and the answer was yes, I'm waiting for feedback on how,when,where,which ......
Will follow up and let you know.
Baitbird
Re: Air nav pro
Postby Baitbird » Mon Jul 01, 2013 10:57 pm
Mine works perfectly
Go to map settings ( the earth logo)
Map Options
, select Airspaces
Airspaces
, and then scroll down to filter options.
Select airspace as nessasary
Airspace classes
and adjust the slider to the applicable levels.
slider
You need to go out to the main screen after each adjustment to see the effect.
Obviously you need to have the right maps installed.
bobthebuilder
Re: Air nav pro
Postby bobthebuilder » Mon Jul 08, 2013 8:35 am
I think that may be my problem.
The map I'm using was one of the free ones called "South Africa - whole country" .... wait .... I think that is for the background image / map. Should I be using a different one?
What about the air spaces? [I'm confused!]
Byron Kirkland
mulderpm
Re: Air nav pro
Postby mulderpm » Mon Jul 08, 2013 1:28 pm
Hi Bob. The map I use is the bought one called South Africa 500k WAC. It is digitised standard 1:500 000 Aeronaughtical maps from the government printers.
JHB area
Resize of Resize of IMG_0082.PNG (92.44 KiB) Viewed 5936 times
Paul Mulder
Tailwinds are the best
ZU-DBC Aquilla
Pretoria
bobthebuilder
Re: Air nav pro
Postby bobthebuilder » Mon Jul 08, 2013 2:35 pm
Ahhh .... Thanks Paul busy downloading it now.
Byron Kirkland
Turbo
Re: Air nav pro
Postby Turbo » Mon Jul 08, 2013 10:12 pm
thanks for that baitbird - i havent had time to mail ANP as yet -- you answered the question.
bobthebuilder
Re: Air nav pro
Postby bobthebuilder » Tue Jul 09, 2013 7:23 am
Hi Paul,
I just had a look at my newly acquired download.
Just like using paper really.... well ..... sort of. The special rules areas are now visible on the map overlay, but are not selectable. Is this correct?
It is definitely better than the free version.
Byron Kirkland
Turbo
Re: Air nav pro
Postby Turbo » Tue Jul 09, 2013 7:39 pm
botthebuilder - mine is also viewable, so are other GF's aswell.
See -- ANR not so kaaaak ... vhpy
bobthebuilder
Re: Air nav pro
Postby bobthebuilder » Wed Jul 10, 2013 7:12 am
I think it's great. Well worth the money.
Byron Kirkland
Turbo
Re: Air nav pro
Postby Turbo » Wed Jul 10, 2013 10:45 am
I second that for sure, use it often, even if its just to see how far above ground I'm flying, that's a neat feature, and changes with terrain automatically.
