I don't see this as being a problem anymore.I think flying with the correct GPS has great potential, but it can't become law until Galileo is fully running,
FF wrote:When it was first deployed, GPS included a feature called Selective Availability (or SA) that introduced intentional errors of up to a hundred meters into the publicly available navigation signals, making it difficult to use for guiding long range missiles to precise targets. Additional accuracy was available in the signal, but in an encrypted form that was only available to the United States military, its allies and a few others, mostly government users.
SA typically added signal errors of up to about 10 m horizontally and 30 m vertically. The inaccuracy of the civilian signal was deliberately encoded so as not to change very quickly, for instance the entire eastern US area might read 30 m off, but 30 m off everywhere and in the same direction. In order to improve the usefulness of GPS for civilian navigation, Differential GPS was used by many civilian GPS receivers to greatly improve accuracy.
During the Gulf War, the shortage of military GPS units and the wide availability of civilian ones among personnel resulted in disabling the Selective Availability. In the 1990s the FAA started pressuring the military to turn off SA permanently. This would save the FAA millions of dollars every year in maintenance of their own, less accurate, radio navigation systems. The military resisted for most of the 1990s, but SA was eventually turned off in 2000 following an announcement by then US President Bill Clinton, allowing all users to enjoy nearly the same level of access.
The US military has developed the ability to locally deny GPS (and other navigation services) to hostile forces in a specific area of crisis without affecting the rest of the world or its own military systems. Such Navigation Warfare uses techniques such as local jamming to replace the blunt, world-wide degradation of civilian GPS service that SA represented.
Ref: Wikipedia
This is where probably the biggest problem lies. Personally I think a good GPS with a moving map display would help solve the problem of pilots flying into controlled airspace "by accident" Such a GPS is to my mind a better investment than a transponder.I think some of the problems are also that we do not take transgressions in uncontrolled airspace seriously.
Pure brillianceWhy not have a manned "safety-radio" in these areas? Just a couple of people manning the radio and purely keeping tabs on those straying too close to the boundary
