Ramp Inspection List
bryan
Re: Ramp Inspection List
Postby bryan » Fri Jul 05, 2013 11:37 am
Yes John and THAT inspector has caused more doubt and heartsore than can be imagined! He needs a good klap since he upset and divided our community so much . He lacks management skills AND knowledge.
Postby John Boucher » Fri Jul 05, 2013 12:05 pm
It does seem that certain persons moving through the ranks of the SAAF and then into positions of other authority seemingly lack people skills. Maybe they forget that they are working within a civilian scenario and this requires a totally different set of skills! Harsh words I utter but have another example of this in Upington playing out :shock:
JvTonder
Postby JvTonder » Mon Aug 12, 2013 10:15 am
Hi John any news on the "final" list of what needs to be in the aircraft (LSA)?
Jaco
Flying feeds the soul!
Postby John Boucher » Mon Aug 12, 2013 12:56 pm
None yet... Waiting in anticipation...
I think we really need to read Part 94.06.07 again.......
The wonderful word NOTWITHSTANDING means IRRESPECTIVE.
Under current regs, if a ramp inspector tries to moer you with regs contrary to what is published... you tell him stuur groete vir ouma!
Operation of amateur-built or production-built aircraft, including microlight aeroplanes
94.06.7
(1) Notwithstanding the provisions of –
(a) regulation 91.03.2 and regulation 91.03.5, a person may operate an amateur-built or production-built aircraft, including a micro
light aeroplane, without carrying on board a current, approved flight manual or flight folio should such carriage not be safely possible;
(b) Subpart 4 of Part 91, a person may operate an amateur-built or production-built aircraft, including a microlight aeroplane, if
the aircraft has been equipped with –
(i) a seat with an approved safety harness or safety belt for each person on board the aircraft;
(ii) a map which covers the complete route of the proposed flight; and
(iii) in the case of flight over water beyond gliding distance from shore, one lifejacket or individual floatation device for each person on board,
stored in a position easily accessible for such persons, or alternatively worn by such persons.
JvTonder
Postby JvTonder » Tue Aug 13, 2013 9:11 am
John Boucher wrote:Under current regs, if a ramp inspector tries to moer you with regs contrary to what is published... you tell him stuur groete vir ouma!
:lol: :lol: :lol: Dankie John :twisted: :twisted:
bobthebuilder
Postby bobthebuilder » Tue Oct 08, 2013 3:07 pm
Hi guys,
Where can I find the current list of requirements for Ramp Inspection on the CAA website?
Is this still valid: http://www.caa.co.za/resource%20center/ ... ctions.htm
I know that a thermometer should be carried. This is not on the list.
What is the deal REALLY wrt fire extinguisher? The link above indicates that I do not require one. (Seven passengers?)
Where can I get the Visual Intercetion Signals" from?
Many thanks,
Byron Kirkland
Induna
Postby Induna » Sat May 31, 2014 3:10 pm
has the ramp inspection requirements been finalised and what are the requirements for LSA aircraft?
Jacques
ZU-RHT | Magni M18 Spartan
Postby Jean Crous » Sun Jun 15, 2014 1:01 pm
Induna wrote:Hi,
Jacques
+1 assebleif/please :roll:
Jean.
Postby Bundy » Fri Jul 11, 2014 6:32 am
JeanTree wrote:
Induna wrote:Hi,
Jacques
Jean.
+2....
What's the progress Rowena? :)
1200 odd members, all with a different take on what constitutes a "Checklist".... ^ xxx
RV12
Postby RV12 » Wed Aug 13, 2014 6:05 pm
peters wrote:Hi Morph, I was at Republic Aircraft Parts today. They at Wonderboom Airport in Pretoria. I bought signal stips there. R 355.00. It's white pvc, a thick type. It has 4 500mm x 2.5m stips a steel reflector and a signal internationally accepted code like paper chart. I,m sur one could make it up. However you can email one of the blokes there. pelcher@lantic.net or call 012 567 5141/2/3 and they can send it to you. This blokes name is William
I have a roll of toilet paper in the plane for that....
mulderpm
Postby mulderpm » Thu Aug 14, 2014 1:29 pm
RV12 wrote:I have a roll of toilet paper in the plane for that....
s023 multipurpose as well.
Paul Mulder
Tailwinds are the best
ZU-DBC Aquilla
Pretoria
Postby Air Hog » Fri Aug 15, 2014 7:18 am
Roll of toilet paper should be on the list as wel anyway. Because we can land in an emergency...
:lol: :roll:
RV12
Postby RV12 » Mon Aug 25, 2014 7:03 pm
We got "nailed" this morning and this is what they found :
1. Verify Contents of first aid kit & Update (old first aid kit)
2. Always Sign LICENSE NO on the flight Folio
3. Always include FUEL UPLIFT on flight folio
4. We need a sticker at the fuel cap that’s says UNLEADED / MOGAS 95 and AVGAS ONLY
5. We need a METAL PLATE in the aerie saying ZU-*** for identification porposes.
6. Replace Compass SWING card to a readable one
7. Keep insurance docs in our aircraft folder
8. Reflective strips required as part of our kit.
Induna
Postby Induna » Mon Aug 25, 2014 7:09 pm
Thanks for the info.
I suppose it also includes the normal stuff like radio license, ATF, flight manual, etc?
Jacques
RV12
Postby RV12 » Mon Aug 25, 2014 7:44 pm
Induna wrote:Thanks for the info.
Jacques
Sorry, yes - items not mentioned were OK except the pilot did not have his latest medical on him. He just had his license. According to the pilot the CAA guy was very helpful. =D*
